since no one would review my c-code on this subject, ih have decided to modified suogata bacis code on sine wave inverter thread. i am using PIC16F72 for the evaluation because that is the processor that is readily available with me now.
The picbasic iam using is the pro demo version and so i appriciate that i can't run a code more than 31 command line.however upon trying to compile the code ,the following erros are reported:
1: Error line 116 :redefinition of label T0CON
2: Error line 119: bad expression
3: Demo limit of 31 command line exceeded (this is understood)
pls, can any one fix these problem for me?.
(a): With the way the modified code stands,can it generate two complimentary sine pwm signals DRIVE1& DRIVE2?.if yes how do i include a delay routine of about 470ns for dead-time control between the two signals?
(b): If the code cannot generate the two complimentary sinepwm signals what do i do to fix the stuff?.
regards,
babalola.
