Sine wave power inverter
Results 1 to 40 of 245
    May 2007
    Hyderabad,India
    Smile Hi Sougata!
    Hope you are fine.
    Thios time I have come up with a weird question.What is the meaning of Sine PWM being 25KHz.
    Say we consder 32 samples it gives ,20ms/32=625uS.
    ===>frequency of each sample is only 1.6KHz .
    Then ecverybody talks of 25 KHz .Could you please explain that a little.
    Feb 2005
    Kolkata-India
    Default It is the carrier PWM Frequency
    You are using a lookup table to modulate a carrier frequency (The PWM). In analogue world this is AM. But the pronciple here is of a class D amplifier. That is your switches are either off/on and not working in the linear region. You can use any frequency thats twice (nyquist) the output frequency mulitplied by the resolution (steps) of the lookup table. Your output transformer and parallel resonant capacitor forms a filter to integrate the modulated PWM into a sinewave. Normally the PWM is kept higher than 20KHz to reduce audible noise in the transformer. While keeping it lower has a certain advantage of lower switching loss.
    Sougata
  1. Replies: 6
    Last Post: - 31st March 2014, 13:25
  2. sine wave inverter
    By BADAL123 in forum Off Topic
    Last Post: - 7th January 2014, 13:20
  3. Low pass filter help - pure sine wave inverter
    By George in forum Off Topic
    Last Post: - 9th April 2011, 05:24
  4. sine inverter
    By anybisi in forum General
    Last Post: - 21st March 2008, 11:08
  5. squre wave inverter
    By pramodsinha in forum Forum Requests
    Last Post: - 11th December 2005, 17:38
