Sine wave power inverter
Results 1 to 40 of 245
    Feb 2005
    Kolkata-India
    Default No idea about your Hardware, Firmware
    I think I have not come across any schematics, code snippets. I don't even know which PIC at what Fosc you are using. May be I missed something as I am not regularly visiting this forum. Details...Please.
    Sougata
    May 2007
    Hyderabad,India
    Default My circuit & schematics
    Dera Sougata,
    I have attached a simple block diagram of Inverter I am working on.
    Hope this would give an Idea of my circuit.
    Kindly suggest what should be feed back routine.
    We are using C with MPLab.
    Thanks and waiting for your reply
    Feb 2005
    Kolkata-India
    Question Still unclear
    I am not an expert on C (uNsUrE of my expertise of PBP aswell ) so may be cannot help much with the code (which has not been posted ) but here are some tips.
    According to your schematic:
    1. Feedback is from one cycle only (not recommended)
    2. Driving through inverters means both MOSFETs doing PWM (wasting energy)
    3. Use Flux reset when changing phase
    4. Be sure that the computed PWM is not eating up cycles and resulting in uneven spread of the modulating PWM
    Please report what happens when no feedback is used. Use a lower duty cycle lookup table to ensure that your MOSFETs are not fried due to full drive. Or use a lower input supply to the Bridge.
    Sougata
    Default Flux Reset
    Quote Originally Posted by sougata View Post
    Dear Sougata,
    What is flux reset when changing phase, can you please give me some more information about it.
    Navneet
    Last edited by Navneet Vinaik; - 16th July 2007 at 05:26. Reason: Spelling Mistake
    May 2007
    Hyderabad,India
    Default Hi sougata!
    I was just trying to understand this concept of flux imbalance control.
    However I could not make out how we do it practically.Do we have to implement it in software or hardware.
    I observed lot of noise while the current wave drops tozero and below.NO load voltage waveform is a correct sinewave.
    Kindly tell me how to implement the flux balance control.
    regards,
    May 2007
    Hyderabad,India
    Exclamation Little more please!
    When feed back is not used the out put is pure sinewave.
    I would also like to understand " I was just trying to understand this concept of flux imbalance control
    regards,
    Feb 2005
    Kolkata-India
    Default These links may help
    I am not qualified enough to explain. So I would suggest you to go through these links.
    http://techtrain.microchip.com/webse...MPS_090106.pdf
    http://www.intersil.com/data/an/AN1246.pdf
    In my software I do this while changing phase.
    1. Switch off the High Side MOSFET
    2. Wait for the dead time.
    3. Switch on both low side (flux reset)
    4. Switch off both low side
    5. Switch on the other High Side
    6. Start PWM on the corresponding low side.
    If you are not getting sinewave in your output while you apply feedback then its your correction algo that is not working. I cannot release our code here without permission from pramod but there is certainly an example of a Sinewave Inverter using C which uses a delta lookup scheme to make computations easier. Here is the link
    http://rapidshare.com/files/43362188/C_Sinewave.rar
    Hope this helps.
    Sougata
    May 2007
    Hyderabad,India
    Default Hi Sougata,little more hepl.
    Dear Sougata,
    It was a great help indeed.
    C-sinewave has lots of info.
    However I would like to know little back ground.Thewre are three tables used ,one for sine wave,one reference sine wave and one error/delta correction.I was not able to understand how he arrive at those tables and the values in the tables.Little more deep in to back ground would probably a great help.
    thanks very much,
    Aug 2008
    Dhaka
    Hi all,
    I am facing another problem, that is sending the pulses from micro controller to the mosfet driver as the sinusoidal pulses from pic micro controller to the driver is very low and hence it is difficult to drive the ir2120. I could use Tc 427 but it is not available here. Hope to get your suggestions to overcome the problem.
    Hope to post the schematics soon. Thanks mincing for your kind suggestion.
    Thanks.
    The strongest man in the world is one, who stands alone for achieving something good.
    পৃথিবীতে সেই সবচেয়ে শক্তিশালী ব্যক্তি, যে ভাল কিছু অর্জনের জন্য একাই নিরন্তর চেষ্টা চালিয়ে যায়।
    May 2007
    Hyderabad,India
    Default Added to previous question!
    Also I would like to know what is the nominal DC volatge used.in that scheme.
    Feb 2005
    Kolkata-India
    Default I am a little off the track at this moment
    Hi Mincing,
    I am sorry I need to put some time and scratch my head to explain the C code. Currently I am a bit involved in some projects (pulling my hair almost always ) But here is a crude explanation.
    For a simple proportional control system the PWM for the sinewave for the current pointer is looked up and the previous PWM is used with the feedback to determine the error. Thus before the current PWM is made through it is corrected for errors by proportionally modifying it.
    Since for your system the max PWM is 255 (8bits) you cannot scale it up any more so your maximum gain is 1.0. Means your hardware should be able to step up the voltage and provide the current at maximum load, minimum permitted input supply. Now what we found in using the 16F is that the multiplication routines were not fast enough (18F has got a hardware multiply) to be calculated on the fly and still leave room for other tasks such as AC Restore Sense (F/V permit), Batt-low sense (+ Indication), PC communication, Overload (Thermal/Power) and Fault sense. So what we did was implement a pseudo hardware PWM. We used the compare in 16 bits and used the High Byte from the sinetable and lowbyte from the error computation. Now we find that PWM results are unsatisfactory. So we decided for lookups table that contains some precomputed results for current and voltage. This speeded up the whole thing but we lost resolution. However for a domestic inverter it was acceptable as the regulation were within specs. I am sorry I cannot reveal any more details.
    So far you have not posted any codes and thus I cannot help you on your code.
    We (Me and Pramod) are planning for a dsPIC based inverter for the next season and if that happens as a reality then we may release the old code to public. No promises however at this moment.
    Best of Luck
    Sougata
  1. Replies: 6
    Last Post: - 31st March 2014, 13:25
  2. sine wave inverter
    By BADAL123 in forum Off Topic
    Last Post: - 7th January 2014, 13:20
  3. Low pass filter help - pure sine wave inverter
    By George in forum Off Topic
    Last Post: - 9th April 2011, 05:24
  4. sine inverter
    By anybisi in forum General
    Last Post: - 21st March 2008, 11:08
  5. squre wave inverter
    By pramodsinha in forum Forum Requests
    Last Post: - 11th December 2005, 17:38
