Thanks for the reply!
I understood that the current drawn(peak current ) is actually higher than what is seen on front panel meter of the Power supply I used.
Do you have any calc. for peak currents that flow in to the bridge?
Actual current or Dc current is only about 1.5 to 2Amps but peak is over 5Amps. at about 15 to 20 V on no load with a transformer connected.
Also what happened to your Double conversion Inverter. I have some documents ,I like to forward to you on the subject.
I am not sure if I can post them here, give me your mail ID I 'll forward the same.
Any one who wants to build HF inverter.
Thanks again!
