Sine wave power inverter
Results 1 to 40 of 245
Threaded View
  1. #11
    batee's Avatar
    batee Guest
    Default IR2184 High/Low Side Driver
    Quote Originally Posted by dknagare
    Can anybody provide me schematic diagram of output stage of HalfBridge as could not found application for dual voltage tapping +/- since the gate voltage should not exceed to say 20 V w.r.t. source of lower side Mosfet/IGBT. This can be achieved by using Bridge driver IC, but I could not find any practical application for it, however a separate bridge driver like TLP250 can be used but practically I have not yet used. Is anybody enlight/share on this with their experience.
    IR2184 is a high side AND low side driver. It generates the extra 10-15V needed above the bridge supply voltage to turn on the top FET, and gets you dead time protection and logic-level inputs, too. It's good for up to 600V, unlike every other FET bridge driver I saw. Two are needed for full bridge operation. If you need programmable deadtime, use the 21844.
    Half-bridge schematic is included in the datasheet.
    http://www.irf.com/product-info/data...ata/ir2184.pdf
    Good luck,
    Bryan A. Thompson
    [email protected]
  1. Replies: 6
    Last Post: - 31st March 2014, 14:25
  2. sine wave inverter
    By BADAL123 in forum Off Topic
    Last Post: - 7th January 2014, 14:20
  3. Low pass filter help - pure sine wave inverter
    By George in forum Off Topic
    Last Post: - 9th April 2011, 06:24
  4. sine inverter
    By anybisi in forum General
    Last Post: - 21st March 2008, 12:08
  5. squre wave inverter
    By pramodsinha in forum Forum Requests
    Last Post: - 11th December 2005, 18:38
