RC Receiver with PIC16F628A Very Glitchy
Results 1 to 10 of 10
    Nov 2006
    Murrieta, CA
    Question RC Receiver with PIC16F628A Very Glitchy
    I read this post http://www.picbasic.co.uk/forum/showthread.php?t=12007 and though the code did help somewhat I am having a lot of glitches when steering the car. All I am doing is turning on lights with the 3rd channel of my RC system.
    Here is my setup.
    Airtronics MX-3S PLL synthesized 3 channel 75Mhz.
    PIC16F628A running at 20mhz.
    Here is the code I am running.
    Define OSC 20
    CMCON = 7
    signal VAR PortA.0
    pulse  VAR BYTE
           PulsIn signal, 1, pulse ' reads signal from receiver
           IF (pulse >= 150) AND (pulse <= 200) Then
              High PortA.1 ' turns LED off
           Else
                Low PortA.1 ' turns LED on
           EndIF
           GoTo main
    There are 10 kinds of people. Those that know binary and those that do not.
    Default Re: RC Receiver with PIC16F628A Very Glitchy
    Any chance your steering servo is spiking your PIC ?
    I would disconnect any motors for the testing, as David suggested.
    The truth is in your electrical scheme ...
    especially around the use of the " magic " .1 or .22µF ceramic capacitor to be located just between the Vdd and Vss pins ( yes, SMD 1206 size is THE thing ! )
    also place a medium value resistor ( 1k to 10k ) in series with your signal input ...
    a 100k resistor between A.0 and Vss is also to consider ...
    last things ... is your LED connected to the Rx supply ??? ...
    and also how much does it draw ???
    and overall ... what kind of supply do you use ?
    Nov 2006
    Murrieta, CA
    I willl Try your suggestions with the Cap and Resistors.
    Ultimately I think the Pulsin timing is wrong and still trying to figure what the correct values should be, or to use pulsin at all.
    Using my Saleag logic analyzer I captured a 50M sample and toggled channel 3 to capture the pulse width.
    With the switch High the width was 1900µs in the off state it was 1500µs. i can upload the captures later if need be.
    So i then looked at 5 different High widths and they ranged from 1895µs to 1910µs.
    The confusing part for me is with a 20Mhz clock this gives me 2µs resolution. What does that mean?
    I then plugged in the values without the steering servo plugged in:
            IF (pulse >= 185) AND (pulse <= 195) Then
    I get no response.
    Alain,
    The board I designed uses the 5v from the ESC.
    I am not driving an LED directly, I am driving a ULN2003 Darlington array which closes the ground for the LEDs but powered from the receiver as well. ULN2003 is rated at 500mA.
    The receiver is powered from the ESC and thus plugged into the 7.2V Battery pack for the car.
    Should i have separate power supplies?
    Gary D.
    my fault - I didn't pay attention to that, only glitches problem - ... it's obvious you do not get any response.
    your pulse is > 1890µs ...
    @ 20 Mhz: 2µs per count
            IF (pulse >= 1850 µs) AND (pulse <= 1950 µs ) Then
    might be written
            IF (pulse >= 1850 /2) AND (pulse <= 1950 /2) Then
    where 2 is your resolution in µS ( or also 40 / Osc freq. )
    second point ... do not set the limits too close to your nominal values ... ( always a +/- 1 count jitter for " pulsin " !!! ) and also think to temp and voltage effects on Tx pulse length ...
    so ...
            IF (pulse >= 925) AND (pulse <= 975 ) Then ...
    will give you fine practical results for nominal values from 1855 to 1945µs.
    one more thing to do is to set the PWRTE fuse in the config : the processor will reset if your supply goes too low due to the ESC and the motor ( surprises should arise ! even with a " BEC " circuit ... )
    also use a nice Electrolytic ( say 100+ µF low ESR ) or tantalum capacitor at the input on your board.
    Nov 2006
    Murrieta, CA
    Lightbulb Re: RC Receiver with PIC16F628A Very Glitchy
    Ok, I got the code working the way i wanted but had to make some alterations.
    First of all - I'm definitely going to have to have a separate power supply for my board as it keeps resetting at full throttle. Even with PWRTE set.
    I had to change:
    Width var byte
    to
    Width var word
    Since the 2µs resolution puts it well beyond 255.
    And after a few minutes of just looking at hundreds if not thousands of pulses on my Logic analyzer it hit me
    Look for the on pulse > turn the light on
    Look for the off pulse > Turn the light off
    Here is my final code:
    define osc 20                        '20Mhz oscillator
    CMCON = 7                           'Turn off Comparators
    Width var word                      '@ 20Mhz channel 3 is 1900µs in the on state. with 2µs resolution thats a value of 950. byte only holds a value of 255.
           Pulsin Porta.0, 1, Width                                          'Wait for a high pulse store the pulse width in the variable "Width."
               if (Width >= 925 ) and ( Width <= 975) then          '1900µs is on state. 1900µs /2 = 950
                  high porta.1
                  goto Check_pulse
               goto Check_pulse
    Check_pulse:
               if (Width >= 475 ) and ( Width <= 525) then           '1000µs is off state. 1000µs /2 = 500
                  low porta.1                                                    'If channel 3 is indeed in the off state turn the LED off.
                  goto Main
               goto Main
    Thanks for all of the help.
    Why not put it in one check and save a cycle?
    Like this (untested):
                  high porta.1
           goto Main
  1. pic16f628a issue
    By Bigandrewgold in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2012, 00:38
  2. PIC16F628A programming help
    By bentech4u in forum mel PIC BASIC
    Last Post: - 29th October 2008, 17:03
  3. Exploring Pic16F628a...
    By mbox in forum mel PIC BASIC Pro
    Last Post: - 18th October 2008, 23:01
  4. Help Pic16f628a
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 26th August 2008, 23:22
  5. PIC16F628A defines
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 08:00
