What is theabsolutely minimal hardware to run BLINK with a PIC18F4620?
Results 1 to 13 of 13
    Default Re: What is theabsolutely minimal hardware to run BLINK with a PIC18F4620?
    1k with high brightness LEDs is plenty.
    I think the problem is a missing register definition somewhere but I can't find it.
    Cheers
    BrianT
    Hi Brian,
    I would guess it's something in the default configs that is/are? at odds with your code, better to hand code the configs so you know what you have.
    DEFINE OSC ??
    Bit 7 of OSCCON, should not be a zero?
    Apr 2007
    Pennsylvania, USA
    bit 7 only matters if using sleep
    add led1=0 near the beginning of your code
    You should also define the osc to 08
    Shawn
    May 2008
    Italy
    Try
    OSCCON = %01111000
    OSCTUNE = %01000000
    DEFINE OSC 32
    I use "INTIO2" but your setting should make no difference if you don't use osc pins as digital in/out.
    Cheers
    Al.
    Sep 2010
    Las Vegas, NV
    I'm not the best at reading the manual for this chip but from what I read on the data sheet OSCTUNE = %01000000 bit 6(PLLEN) can only be used with a 4 or 8 MHz oscillator.
    OSCCON = %01111000 defines a 8 MHz internal oscillator. I think the first part should be of OSCCON should be OSCCON = %011111xx that defines an internal stable oscillator. I don't understand what the last two bits do so that would take some more exploration. It looks like you've got a plethora of options that depend on your specific situation.
    In smaller chips the port usually needs to be set to digital for LEDs to light. I couldn't figure out how to do that for this chip.
    Also, if the LED takes 2.2 volts of the 5 volts applied that leaves 2.8 volts for the 1k resistor. That's only 2.8 milliamps if the chip doesn't drop any voltage. I think that's low and am surprised it will light with 5 volts applied.
    I hope it helps.
    He is using high brightness LEDs. They might consume less than the average 20mA used by common LEDs (might be very high efficiency LEDs).
  1. ADCIN with PIC18F4620
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 4th July 2008, 01:25
  2. PIC18F4620 Troubles
    By CluckShot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2007, 03:02
  3. pic18f4620 and flashlab77
    By igeorge in forum mel PIC BASIC Pro
    Last Post: - 5th November 2006, 01:00
  4. LCD + keyboard matrix minimal I/O
    Last Post: - 21st June 2006, 19:49
  5. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 14:08
