Stuck on porting code to 18F4520
Results 1 to 40 of 43
    Oct 2009
    Default Re: Stuck on porting code to 18F4520
    OK I've reverted to using a counter to dictate when each case statement is reached. The only issue i have is that for the life of me I can't work out how to slow the B_PWM=B_PWM+1 down so the PWM goes from 0 to 255 over the course of 30 minutes without stopping the clock running (such as would happen if a pause statement was used).
    To make this simple I'm going to remove any user programming for now just to make things simple. If anyone can help with some code to assist me in achieving this delay between increasing / decreasing the PWM once every seven seconds without upsetting the clock it would be most appreciated. The timings in the code below are for testing only, so I'm not waiting for things to happen
    If Counter1 < 1200 then
    Blue_day_cycle = NIGHT
    if Counter1 = 1200 then
    Blue_day_cycle = DAWN
    if counter1 =1202 then
    Blue_day_cycle = DUSK
      '*** Do BLUE daily cycle
        select case Blue_Day_Cycle
        case DAWN
        lcdout $FE,$80+13,"DAWN "
                B_PWM = B_PWM+1
            if B_PWM = b_max then
                Blue_Day_Cycle = DAY
        case DAY
        lcdout $FE,$80+13,"DAY  "
                Blue_Day_Cycle = DUSK
        CASE DUSK
        lcdout $FE,$80+13,"DUSK "
            if  B_PWM > B_Min then
                B_PWM = B_PWM - 1
            if B_PWM = b_min then
                Blue_Day_Cycle = NIGHT
        case NIGHT
        lcdout $FE,$80+13,"NIGHT"
            if HH = S2H and MM = S2M then
                Blue_Day_Cycle = DAWN
                b_cnt = 0
        end select
  1. Porting code to new PIC
    Last Post: - 31st December 2010, 23:20
  2. Kind of stuck
    By gti_uk in forum mel PIC BASIC Pro
    Last Post: - 31st May 2009, 20:45
  3. Getting Stuck in loop
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2008, 15:46
  4. Any idea's on porting this to PBP?
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2008, 19:21
  5. Replies: 1
    Last Post: - 8th May 2008, 00:52
