Stuck on porting code to 18F4520 - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 43 of 43
  1. #41
    Oct 2009
    Default Re: Stuck on porting code to 18F4520
    Tried that and the steps are too much, almost rising in 5% increments - this is why I'm looking for an alternative. Shame PBP doesn't support FP and recognise 0.073s as a value
  2. #42
    Jun 2009
    Sc*nthorpe, UK
    The only issue is timing!
    You have set TMR0 at 1/2 second intervals
    ClockLoop: IF intcon.2=0 THEN ClockLoop	'Poll for TMRO overflow
    INTCON.2=0 ' Clear TMRO overflow flag
    HzTimer=HzTimer-$1000	'decrement timer count
    IF HzTimer < $1000  THEN
    IF Col=10 THEN    ' update time'
    SS=SS+1
    IF SS=60 THEN   ' minute
    SS=0
    MM=MM+1
    IF MM=60 THEN    ' hour
    MM=0
    HH=HH+1
    IF HH=24 THEN HH=0
    counter1 = (HH*60)+MM
    Col=Col+1
    HzTimer=HzTimer+$7A12	' Add 0.5 seconds to count
        ' Do something here but must be less than 65.5 mSec
    And again this code works every second
    case DAWN
    lcdout $FE,$80+13,"DAWN "
    if ss//1= 0 then
    if ss != old_ss then
    B_PWM=B_PWM+1
    old_ss=ss
    if B_PWM = b_max then
    Blue_Day_Cycle = DAY
    Change your TMR0 code +$7A12 to a lower value for say 1 msec. Then include for milliseconds in your clock and change all of the ss//1=0 instructions to trigger every 73 ms. I guess there will be more issues thrown up but looks easy to me.
  3. #43
    I'll admit, I don't quite follow what you're doing here but (as far as I can see) with the increased resolution you must change either "step change" per update (what Richard suggest but which basically defeats the incresed resolution) OR change the update rate if you want to keep the orignial "cycle time".
    If the CASE code, which is what's actually updating the PWM dutycycle, is currently executed at 1Hz then changing that to 16Hz will allow B_PWM to reach 4095 in the same amount of time as it's currently taking to reach 255.
    EDIT: Ah, Steve posted while I was typing and retyping....
  1. Porting code to new PIC
    Last Post: - 31st December 2010, 23:20
  2. Kind of stuck
    By gti_uk in forum mel PIC BASIC Pro
    Last Post: - 31st May 2009, 20:45
  3. Getting Stuck in loop
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2008, 15:46
  4. Any idea's on porting this to PBP?
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2008, 19:21
  5. Replies: 1
    Last Post: - 8th May 2008, 00:52
