DS1307 issue
Results 1 to 10 of 10
Thread: DS1307 issue
    Default Re: DS1307 issue
    the 1307 can be restarted by writing $80 and then 0 to the seconds register. the silicon chip magazine published a pic based clock many years back called a
    " PIC TOC " that can be user calibrated for accuracy . I built one 10 years ago and its still running and keeping good time
    Aug 2003
    I wonder if the pic could be driven by the 32KHz crystal directly,
    then you'd only have to use a 1:1 timer to count 15 bit overflow, and that's a second.
    Melanie's Easy and accurate Clocks works, does the PCB have the I2C pullup resistors,
    and if so, have you turned off weak pullups on the chip?
    Aug 2003
    Also, PBP I2CREAD has an error call you could use to verify the I2CREAD happened.
  1. ds1307
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2013, 09:46
  2. ds1307
    By jonas2 in forum Code Examples
    Last Post: - 2nd November 2009, 09:50
  3. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 08:52
  4. DS1307 help
    By Orlando in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 15:17
  5. Ds1307
    By miniman in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 08:29
