DS1307 issue
Results 1 to 10 of 10
Thread: DS1307 issue
    Apr 2011
    Welches, Oregon
    Default Re: DS1307 issue
    I have verified that 1Hz heartbeat is default from power up. Also, a transistor is required to drive LED. I used a 3904, but any similar...
    Oct 2009
    Thanks once again for your input to my posts.
    Here's my basic code.
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 48  ; config settings 18F4580, 20mhz crystal
    ADCON1 = $0F
    clear
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    RTCSec var byte		' Seconds
    RTCMin var byte		' Minutes
    RTCHour var byte	' Hours
    RTCWDay var byte	' Weekday
    RTCDay var byte		' Day
    RTCMonth var byte	' Months
    RTCYear var byte	' Year
    RTCCtrl var byte	' Control
    SetTime var byte	' 12/24 Hour Clock
    SetSec var byte		' Seconds
    SetMin var byte		' Minutes
    SetHour var byte	' Hours
    SetDay var byte		' Day
    SetMonth var byte	' Months
    SetYear var byte	' Year
    RTCSec = 0
    RTCMin = 1
    RTCHour= 2
    RTCWDay =1
    RTCDay  =1
    RTCMonth=10
    RTCYear =13
    RTCCtrl =0
    Counter1 var byte
    counter2 var byte
    counter3 var word
    CounterA var byte	' General purpose Variable
    TimeH var byte      ' Variable to store current hour
    TimeM var Byte      ' Variable to store current minutes
    CCP1CON = %00001100             '
    CCP2CON = %00001100
    'DS18B20 setting
    DQ              VAR     PORTA.5         ' One-wire data pin
    temperature     VAR     WORD            ' Temperature storage
    count_remain    VAR     BYTE            ' Count remaining
    count_per_c     VAR     BYTE            ' Count per degree C
    'analog settings
    ADCON0 = 0                      'Set ADCON0
    ADCON1 = %00001111              'Set D i/o
    CMCON = 7                       'Disable Comparators
    'Port settings
    CCP2CON = %00001100             '
    TRISA  = %11101111              '
    TRISB  = %00000011
    TRISC  = %00011011
    TRISD  = %00000011              '
    SCLpin var PORTC.3               ' RTC pin - clk
    SDApin var PORTC.4               ' RTC pin - data
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    timeH=(RTCHour>>4)                               'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)                         'convert the BCD format of the mins register and store in variable timeM
    If TimeH = 0 and timeM = 0 then
        Counter3 = 0
    If TimeH <0 then
    Counter1 = 0
    If timeH >0 then
    Counter1 = TimeH * 60
    lcdout $FE,$80,"Counter 3 = ",dec Counter3
    If RTCHour.6=1 then
    CounterA=(RTCHour>>4)&$01                           ' Work-Out 12 or 24 hour Display for Hours
    CounterA=(RTCHour>>4)&$03
    CounterA=CounterA*10+(RTCHour&$0F)                  ' Display Hours appropriately for 12 or 24 hour Mode
    If RTCHour.6=1 then
    LCDOut $FE,$D4,#CounterA
    LCDOut $FE,$D4,#CounterA Dig 1,#CounterA Dig 0
    LCDOut ":",#(RTCMin>>4)&$0F,#RTCMin&$0F,"   "
    Counter3 = counterA*60 + TimeM
    GOTO Main
    The strange thing is that even if I remove the DS1307 from the breadboard and connect the SDA wire to the junction of the 4.7K pull up resistor (ie as if the SDA line was being pulled high) the LCD displays 10:10.
    I've also tried code that is running in my current LED lights (for fish tank) using the same chip. This also displays the same issue with the breadboarded chip, but if that chip is removed and placed back in the light controller it picks up the 1307 and displays the current time.
    I'll look at the links and see what develops
    Malcolm
  1. ds1307
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2013, 10:46
  2. ds1307
    By jonas2 in forum Code Examples
    Last Post: - 2nd November 2009, 10:50
  3. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  4. DS1307 help
    By Orlando in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 16:17
  5. Ds1307
    By miniman in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 09:29
