DS1307 issue
Results 1 to 10 of 10
Thread: DS1307 issue
    Oct 2009
    Default DS1307 issue
    Guys need some advice.
    I have an EasyPIC5 board for developing my projects, and for the life of me I have no idea what's happening with getting the time from a DS1307, even though it's been used before to program the PIC with the current version of my project. I have breadboarded the DS1307 and also have a RTC2 module which is basically the DS1307 chip and the resistors / xtal on a small PCB which plugs into a header on the EasyPIC5 board, but still get the same issue, regardless of which PIC I use.
    I've tried some of the examples and test code I wrote a few years back and even re-loaded the latest project, and still the same problem. That is that it displays the date as 10:10:10 and the time as 10 Oct 2010. If I disconnect the DS chip everything reverts to zero (ie 00:00:00 and 00 00 0000). I've used several 18F4580 PICs and loaded code which is running in working projects, and the same thing. I don't think it's a timing issue as the LCD displays other info (such as temperature from a DS18B20).
    My two recent projects use this chip and having loaded the code have the opportunity to manually set the time, but the result isn't written to the DS1307 either. I've checked the jumpers on the EasyPIC5 board and all seem correct (there's not much to change, just pull up / down resistors on the header for that port)
    Anyone have any ideas...
    Apr 2011
    Welches, Oregon
    Default Re: DS1307 issue
    Without code it is difficult to isolate the issue, but if there is any doubt you may use the read and write routines from here: I2C Clock The time and date registers are the same addresses for 1337 and 1307 and that code I know is without problem.
    Beyond, I would verify resistors on I2C lines, "$" to designate hex values and, just because it caused me a problem, try a new crystal (and verify capacitance requirements)? Some of this is unlikely by your symptoms listed, but sometimes just looking again...
    Can you read the status register before applying values? Are "default" register values returning logical results? Any output from heartbeat (I think 1Hz at startup)? I read it requires a transistor to run an LED, but have not tested anything with it. Clock should run from startup, yes? Try only reads to eliminate "write" problems and anything else you can think of to be confident it is "on" and ticking...
    Can you verify data to clock chip on SDA line?
    Apr 2011
    Welches, Oregon
    I have verified that 1Hz heartbeat is default from power up. Also, a transistor is required to drive LED. I used a 3904, but any similar...
    Oct 2009
    Thanks once again for your input to my posts.
    Here's my basic code.
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 48  ; config settings 18F4580, 20mhz crystal
    ADCON1 = $0F
    clear
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    RTCSec var byte		' Seconds
    RTCMin var byte		' Minutes
    RTCHour var byte	' Hours
    RTCWDay var byte	' Weekday
    RTCDay var byte		' Day
    RTCMonth var byte	' Months
    RTCYear var byte	' Year
    RTCCtrl var byte	' Control
    SetTime var byte	' 12/24 Hour Clock
    SetSec var byte		' Seconds
    SetMin var byte		' Minutes
    SetHour var byte	' Hours
    SetDay var byte		' Day
    SetMonth var byte	' Months
    SetYear var byte	' Year
    RTCSec = 0
    RTCMin = 1
    RTCHour= 2
    RTCWDay =1
    RTCDay  =1
    RTCMonth=10
    RTCYear =13
    RTCCtrl =0
    Counter1 var byte
    counter2 var byte
    counter3 var word
    CounterA var byte	' General purpose Variable
    TimeH var byte      ' Variable to store current hour
    TimeM var Byte      ' Variable to store current minutes
    CCP1CON = %00001100             '
    CCP2CON = %00001100
    'DS18B20 setting
    DQ              VAR     PORTA.5         ' One-wire data pin
    temperature     VAR     WORD            ' Temperature storage
    count_remain    VAR     BYTE            ' Count remaining
    count_per_c     VAR     BYTE            ' Count per degree C
    'analog settings
    ADCON0 = 0                      'Set ADCON0
    ADCON1 = %00001111              'Set D i/o
    CMCON = 7                       'Disable Comparators
    'Port settings
    CCP2CON = %00001100             '
    TRISA  = %11101111              '
    TRISB  = %00000011
    TRISC  = %00011011
    TRISD  = %00000011              '
    SCLpin var PORTC.3               ' RTC pin - clk
    SDApin var PORTC.4               ' RTC pin - data
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,RTCDay,RTCMonth,RTCYear,RTCCtrl]
    timeH=(RTCHour>>4)                               'convert the BCD format of the hours register and store in variable timeH
    timeH=(timeH &$03)*10
    timeH=timeH+(RTCHour&$0F)
    timeM=(RTCMin>>4)
    timeM=(timeM &$07)*10
    timeM=timeM+(RTCMin&$0F)                         'convert the BCD format of the mins register and store in variable timeM
    If TimeH = 0 and timeM = 0 then
        Counter3 = 0
    If TimeH <0 then
    Counter1 = 0
    If timeH >0 then
    Counter1 = TimeH * 60
    lcdout $FE,$80,"Counter 3 = ",dec Counter3
    If RTCHour.6=1 then
    CounterA=(RTCHour>>4)&$01                           ' Work-Out 12 or 24 hour Display for Hours
    CounterA=(RTCHour>>4)&$03
    CounterA=CounterA*10+(RTCHour&$0F)                  ' Display Hours appropriately for 12 or 24 hour Mode
    If RTCHour.6=1 then
    LCDOut $FE,$D4,#CounterA
    LCDOut $FE,$D4,#CounterA Dig 1,#CounterA Dig 0
    LCDOut ":",#(RTCMin>>4)&$0F,#RTCMin&$0F,"   "
    Counter3 = counterA*60 + TimeM
    GOTO Main
    The strange thing is that even if I remove the DS1307 from the breadboard and connect the SDA wire to the junction of the 4.7K pull up resistor (ie as if the SDA line was being pulled high) the LCD displays 10:10.
    I've also tried code that is running in my current LED lights (for fish tank) using the same chip. This also displays the same issue with the breadboarded chip, but if that chip is removed and placed back in the light controller it picks up the 1307 and displays the current time.
    I'll look at the links and see what develops
    Malcolm
    I had similar issues with a ds1307 and discovered by reading the data sheet ,that if you don't have a backup battery connected to "vbat"
    then "vbat" must be connected to ground. this fixed the 10:10:10 problem for me
    Oct 2009
    Richard, thanks for the tip, and yes that does fix the 10:10 problem, however I still can't get the DS1307 to run. I've also been porting some other examples that use the timers in the pIC rather than external devices to keep time as I've given up on the DS1307 for now !
    Feb 2011
    I saw the same time numbers awhile ago. The problem came from an accelerometer connected reversed power and ground causing voltage regulator stress. Problem cleared without damage after sensor was removed and installed correctly. Schematic located within http://www.harbornet.com/sunflower/PCB.jpg and code http://www.harbornet.com/sunflower/PCB.pbp
    the 1307 can be restarted by writing $80 and then 0 to the seconds register. the silicon chip magazine published a pic based clock many years back called a
    " PIC TOC " that can be user calibrated for accuracy . I built one 10 years ago and its still running and keeping good time
    Aug 2003
    I wonder if the pic could be driven by the 32KHz crystal directly,
    then you'd only have to use a 1:1 timer to count 15 bit overflow, and that's a second.
    Melanie's Easy and accurate Clocks works, does the PCB have the I2C pullup resistors,
    and if so, have you turned off weak pullups on the chip?
    Aug 2003
    Also, PBP I2CREAD has an error call you could use to verify the I2CREAD happened.
  1. ds1307
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 8th January 2013, 10:46
  2. ds1307
    By jonas2 in forum Code Examples
    Last Post: - 2nd November 2009, 10:50
  3. Code Issue - select case or 'if' issue - not sure why
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 09:52
  4. DS1307 help
    By Orlando in forum mel PIC BASIC Pro
    Last Post: - 17th March 2005, 16:17
  5. Ds1307
    By miniman in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 09:29
