PORTC Weak Pull-ups on PIC16F1503
Results 1 to 13 of 13
    Jan 2011
    Sydney, Australia
    Default PORTC Weak Pull-ups on PIC16F1503
    Hi All,
    I am making good inroads programming the PIC16F1503.
    I am able to set Timer1 and IOC interrupts with Darrel's DT_INT routine and can flash LED's at appropriate rates but I have hit a snag setting up weak pull-ups on PORTC.
    I can set up weak pull-ups on PORTA but I get a syntax error message when compiling with a weak pull-up on PORTC setting.
    My code is as follows:
            __config _CONFIG1, _FOSC_INTOSC & _MCLRE_OFF & _CP_OFF & _CLKOUTEN_OFF
            __config _CONFIG2, _LVP_OFF & _LPBOR_OFF
    OSCCON = %01101000              ; Fosc = 4MHz
                                    ; Clock determined by Fosc<1:0> Config Word
    DEFINE OSC 4                    ; Define socillator as 4MHz
    ' Included the interrupt system
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
            INT_Handler   TMR1_INT,  _ISR,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    ANSELA = 0                      ; Disable PORTA ADC
    ANSELC = 0                      ; Disable PORTC ADC
    DACCON0.7 = 0                   ; Disable DAC
    CM1CON0.7 = 0                   ; Disable comparator 1
    CM2CON0.7 = 0                   ; Disable comparator 2
    T1CON = %00110000               ; Fosc/4
                                    ; 1:8 Prescaler
                                    ; Timer1 OFF
    T1GCON.7 = 0                    ; Timer1 counts regardless of gate function
    TRISA = %00011000               ; PORTA.3 and PORTA.4 as inputs
    TRISC = %00001101               ; PORTC.0, PORTC.2 and PORTC.3 as inputs
    OPTION_REG.7 = 0                ; Enable Weak Pull-ups
    WPUA = %00011000                ; Pull-ups on PORTA.3 and PORTA.4WPUC = 1
    WPUC = %00001101                ; Pull-ups on PORTC.0, PORTC.2 and PORTC.3
    IOCAP = %00011000               ; IOC positive edge register PORTA.3 + PORTA.4
    IOCAN = %00011000               ; IOC negative edge register PORTA.3 + PORTA.4
    The compiler reports a syntax error at the WPUC = %00001101 statement.
    No problems with the WPUA = %00011000 statement so I am bewildered.
    The datasheet clearly states how to use the WPUC register and I believe I have followed the instructions correctly.
    Am I missing something?
    I am using Microcode Studio Version 5.0.0.0, PBP3.0.5.4 and MeLabs U2 programmer.
    Any assistance would be greatly appreciated.
    Cheers
    Barry
    VK2XBP
    Default Re: PORTC Weak Pull-ups on PIC16F1503
    Hi, Barry
    you're right
    WPUC definition is missing in the .PBPINC file ...
    you can add it yourself if you want ( C:\PBP3\DEVICES\PIC16F1503.PBPINC file)
    PBP Team : To be corrected fo Next release
    Ok Alain,
    If you can tell me what address that register is in, it will be added.
    I'm betting you won't find that little bit of information.
    I guess Alain doesn't want to play.
    Instead, he posted a bug report in the melabs forum without doing any research.
    So Barry,
    The 16F1503 doesn't have a WPUC register.
    Yes, I know you'll find references to WPUC in the datasheet ... but it doesn't exist.
    There is a WPUA, but no WPUC.
    If you need pull-ups on PORTC, they'll have to be external.
    Jan 2011
    Sydney, Australia
    Hi Darrel,
    I did a bit of searching on this subject and found some conflicting information.
    Microchip has released an errata document stating WPUC is not available for the PIC16F1503 but I also found another forum where a member had successfully implemented WPUC at H.'020E'
    http://www.microchip.com.edgekey.net...051-print.aspx
    I am not sure who to believe.
    I really don't have room on my board for external pull-up resistors. I chose the PIC16F1503 because it was reported to have weak pull-ups on both PORTA and PORTC.
    Is a workaround possible using H.'020E' address?
    Cheers
    Barry
    VK2XBP
    The person that said he got PORTC pull-ups to work on a 16F1503, has a total of 1 post on that forum.
    Completely unreliable source.
    The register, and the pull-ups do not exist in hardware.
    No amount of messing with the code will change that fact.
    Attempting to write to that address will result in errors from the assembler.
    You can use the FSR's to indirectly write to address 020E ... but no pull-ups will activate on PORTC, because they're not there.
    And when you read it back it returns all 0's.
    I have actually done that with a 16F1503.
    Quote Originally Posted by Aussie Barry
    I'm Crushed!
    Apologies, Darrel ...
    I 've forgotten to download their ....GRRRRR ... F... errata sheet !!!
    errata happens so often it might automatically be included in the download ...
    Jan 2011
    Sydney, Australia
    Hi All,
    I have now swapped over to PIC16F1823 for this project and I am now having difficulty using pins on PORTA as inputs with Weak Pull-ups enabled.
    I have stripped down my code as follows:
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _BOREN_OFF
            __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _WRT_HALF
    DEFINE OSC 4                    ; Define oscillator as 4MHz
    ANSELA = 0                      ; Set PORTA as digital I/O
    ANSELC = 0                      ; Set PORTC as digital I/O
    ADCON0.0 = 0                    ; Disable ADC
    CPSCON0.7 = 0                   ; Disable CPS module
    T1CON.7 = 0                     ; Timer1 OFF
    TRISC = 0                       ; All PORTC as outputs
    TRISA = 1                       ; All PORTA as inputa
    WPUA = %00111111                ; Pull-ups enabled on PORTA
    LED1 var PORTC.5
    LED2 var PORTC.1
    Start:                          ; Flash LED1 and LED2 at 1Hz
        high LED1
        High LED2
        Pause 500
        low LED1
        low LED2
    Goto Start
    The program flashes LED1 and LED2 as expected but I get strange readings when I probe PORTA.1, .2, .4 or .5 with my oscilloscope.
    With PORTA set as digital inputs and weak pull-ups enables on PORTA I would expect those pins to read +5v but they are in fact reading 0v
    I need to connect switches to PORTA.2, .4 and .5 to make selections for my program to function but can't switch these pins to ground if they are already permanently there!
    Can anyone shed any light on what might be happening or what I might be doing wrong?
    Cheers
    Barry
    VK2XBP
  1. Pull-ups on 16F88
    By Steves in forum mel PIC BASIC Pro
    Last Post: - 14th June 2009, 10:19
  2. Weak pull-ups, WPU, and 12F683
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2009, 22:14
  3. HELP on reading the data sheet/weak pull-ups
    By sbobowski in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 20:00
  4. PIC18F4550 internal pull-ups
    By Klaus in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 22:55
  5. Weak Pull-ups
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 12th June 2006, 19:41
