16F877A and LCD HD44780
Results 1 to 39 of 39
    Default Re: 16F877A and LCD HD44780
    1. It will not work without diodes because ADC needs RMS voltage to operate properly and the diodes (shotky works the best) provide the required RMS voltage.
    In that case you've found an error in the sim. Sim show significantly increased "movement" but no other changes.
    George
    epilot,
    I think you're off base here, A translated portion
    BARRA: 'spanish
    IF MARCA1 = 1 THEN 'Si es verdadero
    LINEA = $2 '1 Linea LCD, muestra canal L
    ADCIN 7, CANAL
    MARCA1 = 0
    ELSE 'Si no lo es
    LINEA = $c0 '2 Linea LCD, muestra canal R
    ADCIN 6, CANAL
    MARCA1 = 1
    BAR : 'english
    IF Mark1 = 1 THEN                             ' If true
    LINE = $2: ADCIN 7, CHANNEL: Mark1 = 0        ' 1st line LCD shows L channel
    ELSE                                          ' If it is not
    LINE = $c0: ADCIN 6, CHANNEL: Mark1 = 1       ' 2nd Line LCD shows R channel
    ENDIF 'End of the comparison
    I am pretty sure sensitivity is as I stated above in post 11, ADCON1 & VREF
  1. 20x4 HD44780 LCD Supplier Recomendations
    By retepsnikrep in forum General
    Last Post: - 20th September 2011, 00:43
  2. 2x16 LCD Module with HD44780 + 16F877A
    By comwarrior in forum General
    Last Post: - 19th August 2009, 20:38
  3. Lcd Hd44780
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 15:04
  4. code for LCD-4x20 HD44780....HELP
    By Martin.... in forum mel PIC BASIC
    Last Post: - 24th July 2006, 23:31
  5. LCD 4x20 HD44780
    By inteco in forum mel PIC BASIC
    Last Post: - 27th June 2006, 17:52
