16F877A and LCD HD44780
Results 1 to 39 of 39
    Default Re: 16F877A and LCD HD44780
    Try add flags = 0
    I usually eliminate POT from circuit & tie pin 3 to ground
    The PIC 16F877a has power and ground pins on both sides of the chip, make sure both sides are hooked up
    I did not see any config statement in that code, so how it is running or not is anyone's guess, are you sure it is? Try making a blinking led to be sure.
    The code below is the 16F877A.inc file from my v2.6 install
    ;*  16F877A.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2003 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 11/06/03                                        *
    ;*  Version   : 2.45                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F87xA.INC'  ; PM header
            device  pic16F877A, xt_osc, wdt_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F877A, r = dec, w = -302
            INCLUDE "P16F877A.INC"  ; MPASM  Header
            __config _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    Notice it says XT_OSC, this is incorrect for your 20 mhz osc, it should say HS_OSC, for any resonator and crystals above 4 mhz, this is an oscillator power setting, either change it here or comment this line out and put the config in your code. This statement assumes you are using a version older than 3.0
    It is always better to copy paste your code than a link to somewhere,however; a link does make a good supplemental.
  1. 20x4 HD44780 LCD Supplier Recomendations
    By retepsnikrep in forum General
    Last Post: - 20th September 2011, 00:43
  2. 2x16 LCD Module with HD44780 + 16F877A
    By comwarrior in forum General
    Last Post: - 19th August 2009, 20:38
  3. Lcd Hd44780
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 15:04
  4. code for LCD-4x20 HD44780....HELP
    By Martin.... in forum mel PIC BASIC
    Last Post: - 24th July 2006, 23:31
  5. LCD 4x20 HD44780
    By inteco in forum mel PIC BASIC
    Last Post: - 27th June 2006, 17:52
