coundown problem on LCD
Results 1 to 7 of 7
    May 2005
    Red face coundown problem on LCD
    Hi everybody.
    i again have problem with pic
    i am trying to countdown the hours minutes and seconds
    like 01:19:49 and lcd will show the countdown
    if i press button1 i want to add 30 minute
    i start like this
    second VAR BYTE [59] 'I WANT TO LIMIT THE TIME
    minute VAR BYTE[59]
    hour VAR BYTE[59]
    second=0 'start with 0
    minute=0 'start with 0
    hour=0 'start with 0
    button porta.4 ,0,0,0,b1,1,plus_the_count
    simlpy my codes re like these but the compiler allways give error
    (unable to fit second)
    after then i try it basicly
    '''''''''''''''''''''''''''''''''''''''''''''''''r eal codes for 16F628'''''''''''''''''''''''''''''''''''''''''''' '
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    saniye var byte[59]
    dakika var byte[59]
    saat var byte[59]
    saniye=0
    dakika=0
    saat=0
    loop:
    saniye = saniye -1
    if dakika =00 then saat= saat-1
    LCDOut $FE,1 'ekranı temizle
    lcdout "KALAN SURE"
    LCDOut $Fe,$C0
    LCDOUT #saat,":",#dakika,":",#saniye
    goto loop
    '''''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''end'''''''' ''''''''''''''''''''''''''''''''''''
    and still have problem "unable to fit variable saniye"
    how can i limit the numbers when reverse counting?
    Asking is not a shame but not learning is a SHAME!!!
    SuB-ZeRo, You are using almost all of the available ram with the 3 arrays you are trying to declare. The processor you are using only has 192 bytes available and you are declaring 180 of them. Why?
    SuB-ZeRo,
    I beleive you want to do something like this:
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    saniye var byte
    dakika var byte
    saat var byte
    saniye=59
    dakika=59
    saat=59
    loop:
    lcdout "KALAN SURE"
    LCDOut $Fe,$C0
    saniye = saniye - 1
    if saniye > 59 then
    saniye = 59
    dakika = dakika - 1
    if dakika > 59 then
    dakika = 59
    saat = saat - 1
    if saat > 59 then
    saat = 59
    goto loop
    Jun 2005
    Wisconsin
    Are you sure you are using the following line correctly?
    This doesn't limit the byte to 59 it creates an array of 59 bytes. It sounds like you want 1 byte that doesn't go any higher than 59. I would do the following within a loop:
    IF UP=0 Then ' Button Up command
    While UP=0:Wend
    second = v+1
    IF second > 59 Then second = 1
    LCDOut $FE,1
    EndIF
    May 2005
    Unhappy Hmmm everybody understand me wrong :(
    i thing every body understand me wrong coz i want to set i timer that start with 00:00:00 and if i push the button that connected to the RA4 it will plus the reverse timer 30 minute 00:00:00 will become 00:30:00 after than countdown beguns 00:29:59 .......00:28:59...... till 00:00:00 but when the countdown starts or continues if i push the button again for example when the time 00:25:19 it will plus 30 minute again and the time will become 00:55:19 every push will plus 30 minute 01:25:19 ... 01:55:19 and goes.My problem is when i try to start the time from 00:00:00 on the LCD i see 0:0:0 if i push the button it becomes 0:30:0 after than it goes 0:29:1=>0:29:0=>0:28:1=>0:28:0 i really cant find the problem
    Jun 2005
    Wisconsin
    try:
    LCDOUT DEC2 saat,":",DEC2 dakika,":",DEC2 saniye
    DEC2 will always print two digits to your display.
    May 2005
    Talking everything works no problem
    ok i resolve the problem the real problem is putting the codes to the right place i am getting to learn programming in pic basic
    Last edited by SuB-ZeRo; - 7th June 2005 at 01:15. Reason: I edit coz i resolve some problems
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 08:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 19:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 15:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. Need help with LCD number display.
