Rctime and ntc
Results 1 to 15 of 15
Thread: Rctime and ntc
    May 2008
    Italy
    Default Re: Rctime and ntc
    NTC are negative termoresistor. Which means that while temperature increases resistance of the termistor decrease, so they are inversely proportional.
    Al.
    RE: Yes it does but it does not mean they are linear, which is why I do not think simple division will have accuracy.
    thanks for the answers, I do not need to be precise I just have to control the switching on and off at a given temperature a fan then, that there is an error of a degree I do not care.
    Sep 2010
    Las Vegas, NV
    Of the one specific thermistor I looked I downloaded the excel file and from 0 degree to 100 degree the curve is indeed exponential. I tried to import the data into excel but I've forgotten how to get it to give you a formula to fit the data entered. I browsed a few others and they all look about the same but you can find the math for a precise formula at http://www.epcos.com/web/generator/W...dardizedRT.pdf. Putting that into PBP will be a challenge to say the least.
    This site though has a much easier formula if you know a little of your thermistors' data:http://www.mstarlabs.com/sensors/the...libration.html
    Though I thought this site gave you a better idea of how to find the right formula:http://www.cantherm.com/products/the...osing_ntc.html
    thank you very much I will try to set formulas in pbp and let you know. thank you very much. if someone already has some sample code that can assist me I would be most grateful if you would provide me. greetings
  1. NTC thermistor temperature monitering
    By Divinci in forum mel PIC BASIC Pro
    Last Post: - 15th December 2012, 01:54
  2. NTC thermistor temperature sensing
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 16th January 2011, 09:56
  3. can someone help me with RCTIME
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 17th May 2007, 01:30
  4. NTC Thermistor with PWM
    By shredder in forum Schematics
    Last Post: - 14th March 2007, 00:27
  5. NTC resistor
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 29th September 2005, 19:16
