Re: Problem with PIC 16F628A resetting intermittently
Hello Harold,
I would suggest a couple of changes:
1. BOREN_OFF
2. eliminate all those LOOOOONG pauses by using for next loops with short pauses and big numbers
3. Try to keep subroutines succinct and make sure they terminate with return so you do not get stack overflow problems
I am not sure why you zero counter variables and never use the zero value counting 1 to 5, probably makes no diff but I would
count 0 to 4 just so as not to confuse myself.
#2 is so you can interrupt the loop if you ever need to lets say you add some LCD display as a result of a push button interrupt, you will not
have to wait 5 minutes for the loop to respond.
