Problem with PIC 16F628A resetting intermittently
Results 1 to 9 of 9
    Sep 2011
    Default Problem with PIC 16F628A resetting intermittently
    I have a program where the 16F628A resets intermittently.
    The program controls a remote heater using a Dallas DS18B20 temperature sensor.
    Initilization:
    The circuit breaker is turned on and a relay enegizes keeping the heater off for 30 seconds. The operator then walks to where the heater is which takes about 30 seconds.
    The relay then deenegizes to turn the heater on and the operator can verify operation.
    After 30 seconds the relay energizes and the heater turns off then then goes to the main part of program.
    The heater cycles as it goes above or below the setpoints.
    Problem:
    The heater cycles about 15 times per day normally, but about once or twice a day the PIC will reset and go into the initilazation sequence and the continue operation. This is not good for the heater as short on sequences are not good.
    Solutions tried:
    Used various power supplies, different temperature sensors, shielded and unshielded cable, noise filters all without any change.
    I am posting the program as perhaps my logic is not correct or out of sequence.
    Any suggestions?
    '*  Name    : Base_new_5.bas                                    *
    ' RA2 as DQ for DS18B20
    ' RB3 as output to 0AC5A
    ' for 16F628A
       __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _LVP_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_OFF & _BOREN_ON
    '1 - RA2    - DQ for DS18B20
    '2 - RA3
    '3 - RA4
    '4 - RA5
    '5 - Vss
    '6 - RB0
    '7 - RB1
    '8 - RB2
    '9 - RB3    - output pin for OAC5A
    '10 - RB4
    '11 - RB5
    '12 - RB6
    '13 - RB7
    '14 - Vdd
    '15 - RA6
    '16 - RA7
    '17 - RA0
    '18 - RA1
    OPTION_REG.7 = 0       ' turn on weak pullups
    CMCON = 7              ' comparitors off port set for digital
    VRCON     = 0          ' A/D Voltage reference disabled
    TRISA     = %00000100  ' A2 as input all others outputs
    TRISB     = %00000000  '  all are outputs
    Comm_Pin    VAR     PortA.2 ' One-wire Data-Pin on PortA.2
    Sign        VAR     BYTE    ' +/- sign for temp display
    RAWTEMP     VAR     WORD    'Read raw temperature from DS18B20
    VeryCold    VAR     RAWTEMP.Bit11   ' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    Busy        VAR     BIT
    SetPoint    var     byte
    s           var     byte
    setpointhigh    var     byte
    setpointlow     var     byte
    setpointlow = 5
    setpointhigh = 7
        high portb.3          'no power for 30 seconds
        pause 30000
        low portb.3           'power for 30 second to verify it is on
        PAUSE 30000
        high portb.3          'no power until requested
    '    s = 0
        gosub Start_Convert                 ' get temperature reading
        if VeryCold = 1 then                'if the bit is set then turn heater on for 5 minutes
                    low portb.3
                    gosub FiveMinute
       RAWTEMP = RAWTEMP */1600
       RAWTEMP = RAWTEMP / 100              'convert to degrees C
        if RAWTEMP <= setpointlow - 1 then            ' on setpoint    = turn heater on
                        low portb.3
                        gosub TenMinute
         if  RAWTEMP >= setpointhigh then            ' off setpoint   = turn heater off
                        high portb.3
        pause 1000                          ' wait 1 second
        goto Main                           ' do it again
    TenMinute:
        for s = 1 to 10
            pause 60000
        next s
        s = 0
     FiveMinute:
        for s = 1 to 5
            pause 60000
        next s
        s = 0
     Start_Convert:
        OWOUT Comm_Pin, 1, [$CC, $44] ' Skip ROM search & do temp conversion
        Wait_Up:
            OWIN Comm_Pin, 4, [Busy]  ' Read busy-bit
    '        pauseus 25
            IF busy = 0 THEN Wait_up
        OWOUT Comm_Pin, 1, [$CC, $BE]       ' Skip ROM search & read scratchpad memory
        OWIN Comm_Pin, 2, [RAWTEMP.LowByte, RAWTEMP.HighByte] '  OWIN can read in a BIT or a BYTE
    Harold
    Default Re: Problem with PIC 16F628A resetting intermittently
    Hello Harold,
    I would suggest a couple of changes:
    1. BOREN_OFF
    2. eliminate all those LOOOOONG pauses by using for next loops with short pauses and big numbers
    3. Try to keep subroutines succinct and make sure they terminate with return so you do not get stack overflow problems
    I am not sure why you zero counter variables and never use the zero value counting 1 to 5, probably makes no diff but I would
    count 0 to 4 just so as not to confuse myself.
    #2 is so you can interrupt the loop if you ever need to lets say you add some LCD display as a result of a push button interrupt, you will not
    have to wait 5 minutes for the loop to respond.
    From my experience in industrial control ...
    1) mains is " not so clean " and a strong filtering + backup battery generally solve 99% of regulation problems.
    2) use a hardware reset circuit like with a MC 33164P5 ...
    3) use Hardware pullups and not "software" ones ...
    4) a CRC check could be a nice idea ...
    5) take great care of your line to the DS1820 ... ( see Dallas design ideas for rugged nets ... )
    6) you could add some checking of the Status and Pcon registers to help identifiying the problem ( add a couple of leds i.e. )
    Besides what Archangel and Acetronics suggest, I'd also suspect the load. Your heating coil draws a lot of current, and I suspect the spurious resets would be happenning when the relay releases.
    A snubber circuit accross the load might help.
    Or, a solidstate relay that switches at zero crossover?
    Anand
    . . . Your heating coil draws a lot of current, and I suspect the spurious resets would be happening when the relay releases.
    Anand
    Wow, it did not occur to me it was an electric resistive heater, I was thinking it was gas . . . Good call.
    Sep 2011
    Thanks to all for sending suggestions to solve my problem.
    I do have a commercial opto isolation module in the circuit and this sends a voltage to the remote contactor coil at the heater.
    I have added command to my code to display on a LCD so I could follow the program flow and monitor where the problem occurs.
    I have now had more fun for the last 11 hours simulating and watching the program do its work with the actual heater disconnected. (more fun than watching paint dry) Ha Ha.
    The program did fail twice in that time and it appears that it goes to the temperature read subroutine and then suddenly resets. The point when this happened was when the temperature just got to the minimum trigger setpoint. My LCD display did not indicate that it left the subroutine and went to the comparison section.
    I am going to try battery power but I do not suspect that is the problem as I have a 2A 5V supply that is fed off a different circuit than what the heater is on.
    I will keep plugging along.
    Harold
    Hi Harold,
    What kind of lighting is in the area you are working? Sometimes Fluorescent lights make unshielded PICs behave badly.
    Quote Originally Posted by Archangel View Post
    Hi Harold,
    I didn't know that. What kind of shielding? A metal enclosure?
    Hi Robert,
    I scrapped out a TV a Magnavox that had metal shields around it's CPU chips, they fit under and over them, only the pins were not shielded. Some forum members here have reported this problem in the past. I think breadboards would be esp. susceptible . . Remember RF crawls around on the surface whereas DC goes through a conductor.
  1. Without resetting....Switching PIC over to Backup Battery
    By financecatalyst in forum Schematics
    Last Post: - 29th December 2010, 15:23
  2. PIC keeps resetting when executing subroutine
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 27th August 2009, 08:03
  3. 16F628A fuse problem
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 26th July 2008, 08:51
  4. PIC chip resetting. Very weird
    Last Post: - 28th October 2007, 18:07
  5. Pic resetting
    Last Post: - 1st January 2007, 22:00
