Addressing ports via offset using lookup command
Results 1 to 11 of 11
    Feb 2012
    PERTH AUSTRALIA
    Default Addressing ports via offset using lookup command
    HI GUYS ,
    Hendrik some time ago showed a little trick where by port may be accessed via the lookup command using an offset
    This works because most of the ports are usually memory mapped sequentially from the base port of portA.0
    How ever if they are not can the other ports not in memory sequence be addressed in this manor , if so how ?
    cheers
    sheldon
    example chip 16f1947 has ports A-G
    portA.0 - portE.7 are arranged in memory
    Memloc - Port - Lookup offset value from portA
    00Ch port A.0-7 , 0-7
    00Dh port B.0-7 . 8-15
    00Eh Port C.0-7 , 16-23
    00Fh Port D.0-7 , 24-31
    010h Port E.0-7 , 32-39
    28Ch Port F.0-7 , ???
    28Dh Port G0.5 , ????
    As such ports A- E can be used in lookup command like this
    For  T =  0 to 10                                     ' Select 10 ports for Pulses
           LOOKUP T, [1,1,2,4,5,16,17,18,19,20,21],PortOffset   ' Offsets from Port A to point to PortA & PortsC ( value of offset relates to Port bits in mem map of chip)
    next T
    Default Re: Addressing ports via offset using lookup command
    Since PortA is at 00Ch and PortF is at 28Ch the "distance" between them would be 28Ch - 00Ch = 280h or 640 in decimal.
    Now, LOOKUP can only retrieve 8bit values from its table so it's not going to work. You'll have to use LOOKUP2.
    Next possible issue is that the registers for Ports F and G are not in the same bank as those for Ports A-E so I'm not sure it's work....
    Feb 2012
    PERTH AUSTRALIA
    well it compiles ,after making the change to lookup2 , and portoffset to a word variable
    but ill have to wait for the pcbs to arrive to test it
    cheers hendrick
    When you are using the "Bit Offset from Port" method, it is using "BIT Array" operations internally.
    BIT array's have a limit of 256 elements.
    Giving it a WORD sized offset will not work.
    It will compile using a WORD, but it will only use the LowByte of that value.
    Feb 2012
    PERTH AUSTRALIA
    ok thanks darrel is there another coding method to solve this
     T = 0                                                  ' Ensure 0
           For  T =  0 to 10                                    ' Select IR LED for Pulses
             LOOKUP2 T, [32,32,33,34,35,36,37,38,39,640,641],PortOffset   ' Offsets from Port A to point to PortE(32- 39) & PortsF (640,641) ( value of offset relats to Port bits in mem map of chip)
                Cycles = 0                                    ' Set to 0
             if  T = 0  then
                Pulse_cnt = 38                                 ' add 1ms(adj) Header pause ( pulse on time ) before start of IR1 only so to show its the its the Start of the scan
                Pulse_cnt = Pulsetmp                           ' restore value  set from Volts get routin when changed by pulse T = 0
             endif                                             ' add 1ms(adj) Header pause ( pulse on time ) before start of IR1 only so to show its the its the Start of the scan
            for Cycles = 1 to Pulse_cnt                        ' Set base pulse count cycles for IR lEDs ( 9 x 26uS) -17us = 217us
                      PORTA.0[PortOffset] = 1                  ' Set IR LED High
                      pauseus 2                                ' Remain on for 9uS  (adj)
                      PORTA.0[PortOffset] = 0                  ' Set IR LED Low
                      pauseus 9                                ' remain off for 17uS  ( adj)
            next Cycles
           pauseus Pulse_off                                   ' Wait 300us (Adj 276) between pulse bursts and selecting next IR LED
          Next T
    Sep 2009
    You can offset from PORTE or PORTF.
    For example:
                      IF T<9 THEN
                          PORTE.0[PortOffset] = 1                  ' Set IR LED High
                          PORTE.0[PortOffset] = 0                  ' Set IR LED Low
                          PORTF.0[PortOffset] = 1                  ' Set IR LED High
                          PORTF.0[PortOffset] = 0                  ' Set IR LED Low
            next Cycles
    And you need 2 lookup tables, one for PORTE another for PORTF.
    Treat them as if all the ports were contiguous.
    A = 0-7
    B = 8-15
    C = 16-23
    D = 24-31
    E = 32-39
    F = 40-47
    G = 48-55
    Then if the offset is greater than 39 ... change the port that it offsets from, and subtract 40 from the offset.
    IF PortOffset < 40 THEN
        PORTA.0(PortOffset) = 1
        PORTF.0(PortOffset-40) = 1
    Feb 2012
    PERTH AUSTRALIA
    thanks guys ,
    darrel i did not think to treat them as contiguous when they are not , but by changing the start port solves that issue
    the extra if then ,else commands , may cause some delays in the timing ill have to see the output it creates to check it
    cheers sheldon
    Quote Originally Posted by longpole001 View Post
    Ha! That's funny.
    By using a PORT offset to begin with, it's doing "Array" operations that will take more time than a simple BYTE comparison and subtraction.
    The comparison takes 4 cycles if true, 5 if false.
    The subtraction takes 4 cycles if >= 40.
    The array operation takes ... 30 instruction cycles.
    Feb 2012
    PERTH AUSTRALIA
    if you can recommend a better way to do it , please show , as it worked not aware of better way when i started to do it
    Feb 2012
    PERTH AUSTRALIA
    because the on and off time is short , normally would need to do it in assembler , but my asm sucks and need to learn more for sure , even more so when multi ports have to be addressed , this seemed to work ok and is still likely to as you say its only a few more cycles , and i still have pauses in this routine anyway, which can be removed
  1. PicBasic Lookup command
    By queenidog in forum mel PIC BASIC
    Last Post: - 18th June 2016, 21:54
  2. 10bit ADC with offset on 16F88
    By Amoque in forum mel PIC BASIC Pro
    Last Post: - 1st April 2012, 16:11
  3. DS1820 Negative Numbers and OffSet
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2011, 22:53
  4. dt int timer1 ignores offset value
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 15th June 2010, 10:53
  5. Offset to variable howto ?
    Last Post: - 3rd October 2008, 10:36
