actually I had idea to put few passive component for making one-shout for short period and one shut for longer period
after that i timed mssp module to average carrier frequency (positive + negative periode) this can be done using add register i done it with 16f1827 + internal osc +PLL
intention was to make it on both MSSP modules, but i have problem using both paralell.....
ok, this is working, and now timing and hw-accelerated sending is piece of cake for basic timings.....
but i miss memory, so i have to port all onto 46k22 which is still dual mssp internal 64mhz, cheap, need to read erratas frequently but almost always there is workaround
why more memory ? because i want to have ability to change any led, so you need 3 byte per led, and for 100 leds, this is 300 byte of ram....
this days i obtained psoc4 and i want to organize UDB module for hardware accelerator for sw led, but ah.... this is totally hardCore
http://www.element14.com/community/b...ioneer-dev-kit
noone for now is'n sharing code/project, so i can learn from working project.... there is actually other shared article as arduino or others...
i hope i at least point you in some direction....
reagards
