Second I2C address not responding
Results 1 to 22 of 22
    Nov 2007
    West Covina, CA
    Default Re: Second I2C address not responding
    I'm confused how the 1st I2C address is even responding.
    Your device address range, dependent on which address bits are tied HI, is between $40 and $4E according the data sheet.
    Name:  PCF8574 I2C address.JPG
    01000000 = $40 ' With A2, A1, A0 all set to 0 : (bit 0 set to Write)
    01001110 = $4E ' With A2, A1, A0 all set to 1 : (bit 0 set to Write)
    Verify which of your PCF8574 address select pins are pulled High and correct them on your current code because other than that it looks right.
    Art, the 10ms PAUSE in the manual is referring to writing to an EEPROM that needs that Write delay because it's slow getting out of bed like me.
    Louie
    Apr 2011
    Welches, Oregon
    The data sheet link passed on by Archangel is much appreciated! Way easier to read... thanks again.
    LinkMTech- I have to be honest, the chips may be tha "A" version. I sandwiched the chip between the board and the LCD, so no way to tell, but I also marked each board with a correct address as I verified their function while building. I didn't think to mention the discrepancy because they work individually and it never occurred to me that the addresses could be part of the problem. It does make sense to check this out though as, of course, until the problem is found it may be anywhere.
    I am at work presently and have no access to try any of these solutions for some hours, but I will give each every effort and report back soonest.
    Amoque
    These things are worth the time spent, they are beautiful when lit. Two are very nearly (I mean micro-smidgens different) the same size as the 128X64 GLCDS available in matching background and display color. Already I imagine a modular weather station (like a group of framed pictures) hanging on my den wall with groups of these providing clear visibility from anywhere in the room. Might even throw in a GLCD or two for graph functions. Gold foil touch sensors under glass... I tell ya boys, that's class, and I'm gonna get me some.
  1. Replies: 2
    Last Post: - 27th August 2013, 23:07
  2. How to find I2C Slave address of PIC24FJ256GA110?
    By sharath12 in forum Off Topic
    Last Post: - 19th March 2012, 15:21
  3. PORTC.4 and C.5 not responding to inputs.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 22:41
  4. 4 bit address decoding I2C chip
    By ecoli-557 in forum General
    Last Post: - 10th June 2008, 18:26
  5. Pic 18f252 not responding
    By gringo332 in forum General
    Last Post: - 22nd March 2007, 22:21
