Help guys...communication issue, I think?
Results 1 to 17 of 17
    Dec 2005
    Salt Lake City, Ut, USA
    Default Help guys...communication issue, I think?
    Hello all,
    I'm back here posting due to some massive brain fry over my latest project. Here's what I've got:
    PC to a Trendnet TU-S9 (USB to RS232 adapter).
    From there, into a custom board with a MAX232 to a MAX3081 RS422 chip (Rx+, Rx-,Tx+,Tx-,Ground).
    From there, into board(s) that have a MAX3081, which are then tied into the USARTs of the MCUs.
    All of the RS422 wiring is over Cat5e with RJ-45 connectors.
    Each board has 2 RJ-45 connectors, wired in parallel, to facilitate a daisy chain configuration.
    At present, I have 2 boards: 1 that does ADC stuff (PIC16F1936), and the other that does strictly outputs (PIC16F887).
    I think that gets the hardware out of the way.
    As far as the software, I'm running them with Term.exe @ 57600,8,N,1.
    Here's where it gets weird
    When I plug either board in by itself, all is good (receive from the PC and transmit back from the MCU)
    When I plug both boards in (daisy chained), both boards receive from the PC just fine but
    I can only receive a response back from my 887 output board, although I can send commands just fine to both
    of them. I verify this by manually switching some outputs on the 1936 board. When I expect a serial response
    from the 1936 board, all I seem to receive at the terminal is a carriage return (or so it appears).
    I hope that isn't confusing
    Here's the code for the 2 different boards, so maybe one of you fine folks can determine where I'm going astray.
    Of course, the following code is clipped for irrelevant content.
    Thanks for taking a peek at the code, and for the help.
    Chris
    *As you will see, I even tried to enable the serial transmit only when it is needed. That got me to the point
    of the 887 board responding back to the PC. Previous to that, neither boards would respond.
    1936 code:
    '***********************************SERIAL INTERRUPT**************************************
    RS232in:
    @ INT_DISABLE IOC_INT
    @ INT_DISABLE TMR1_INT
    @ INT_DISABLE RX_INT
        low RxLED   'Rx LED ON
        HSERIN 300,Stall,[DEC3 SerialIn]
        If SerialIn = 255 then gosub GoodQualifier
        Stall:
        while PIR1.5
            SerialIn = RCREG
        wend
        high RxLED  'Rx LED OFF
    @ INT_ENABLE IOC_INT
    @ INT_ENABLE TMR1_INT
    @ INT_ENABLE RX_INT
    @ INT_RETURN
    GoodQualifier:
    T1CON   = timeroff           'Timer Off
    hserin 300,Junk,[str SerBuff\10\"~"]
    'Parse ASCII CmdPrefix
    CmdPrefix = SerBuff[0]
    'Convert Address from ASCII to DECIMAL
    for x = 1 to 3
        SerBuff[x] = (SerBuff[x]-"0")
    next
    'Build the DECIMAL address
    CmdAddress = SerBuff[1] * 100
    CmdAddress = CmdAddress + SerBuff[2] * 10
    CmdAddress = CmdAddress + SerBuff[3]
        if CmdPrefix = "A" then
            '-------------------------Address Module----------------------------
                write 0,Address
                LOW TxLED
                TXSTA = 36
                    HSEROUT [CmdPrefix,DEC3 Address,13]
                    WHILE PIR1.4 = 0 : WEND
                TXSTA = 4
                HIGH TxLED
                read 0,Address
        '--------------------Address Mismatch--------------------------
        if CmdAddress = Address then
            TXSTA = 36  'Turn ON transmitter
            '-------------------------Command Module----------------------------
            if CmdPrefix = "O" then   'Oaaaoo   (6)
                'Convert CmdOutput from ASCII to DECIMAL
                for x = 4 to 5
                next
                CmdOutput = SerBuff[4] * 10
                CmdOutput = CmdOutput + SerBuff[5]
                select case CmdOutput
                    case 10
                        OUT1 = 0
                    case 20
                        OUT2 = 0
                    case 30
                        OUT3 = 0
                    case 11
                        OUT1 = 1
                    case 21
                        OUT2 = 1
                    case 31
                        OUT3 = 1
                    CASE ELSE
                        goto Junk
                    END SELECT
                HSEROUT [CmdPrefix,DEC3 Address,dec2 CmdOutput,13]
            if CmdPrefix = "Q" then     'Qaaa       (4)
                low TxLED                                           'Tx LED ON
                HSEROUT [CmdPrefix,DEC3 Address, _
                        ",",DEC VOLTS,",",DEC TempF,",",DEC Amps, _
                        ",",dec PORTA.1,",",DEC PORTA.0,",",DEC PORTA.4,13]
                high TxLED                                          'Tx LED OFF
            if CmdPrefix = "P" then     'Paaa       (4)
                HSEROUT [CmdPrefix,DEC3 Address,DEC1 ModType,13]
            if CmdPrefix = "M" then     'Maaallvvv  (9)
                '10=LowVolts, 11=HighVolts, 12=LowTemp, 13=HighTemp, 14=LowCurrent, 15=HighCurrent
                'M001                     Board Address
                '       10                  EEProm Location (Low Trip)
                '          255             Low Trip Value
                'Convert eepromloc from ASCII to DECIMAL    Maaaeevvv
                for x = 4 to 5
                next
                'Build the DECIMAL
                eepromloc = SerBuff[4] * 10
                eepromloc = eepromloc + SerBuff[5]
                if (eepromloc < 10) OR (eepromloc > 15) then
                    goto Junk
                'Convert tripval from ASCII to DECIMAL
                for x = 6 to 8
                next
                'Build the DECIMAL
                tripval = SerBuff[6] * 100
                tripval = tripval + SerBuff[7] * 10
                tripval = tripval + SerBuff[8]
                write eepromloc,tripval
                HSEROUT [CmdPrefix,DEC3 Address,dec2 eepromloc,dec3 tripval,13]
                ReReadVals = 1
            if CmdPrefix = "C" then   '(CONTROL)    'Caaa1
                ManualControl = (SerBuff[4]-"0")
                HSEROUT [CmdPrefix,DEC3 Address,dec1 ManualControl,13]
            WHILE PIR1.4 = 0 : WEND 'If we're still transmitting, wait here
            TXSTA = 4               'Turn OFF transmitter
    Junk:
    for x = 0 to 9
        SerBuff[x] = " "
    next
    T1CON   = timeron           'Timer ON
    887 code:
    '*********************************SERIAL INPUT**********************************
    RS232in:
        HSERIN 300,Stall, [DEC3 SerialIn]
        Stall:
        while PIR1.5
            SerialIn = RCREG
        wend
    @ INT_ENABLE RX_INT
    @ INT_RETURN
    GoodQualifier:
    T1CON   = timeroff
    for x = 1 to 3
    next
            'Aaaa   (4)
            IF CmdPrefix = "A" THEN
                write 0,Address
                TXSTA = 36
                TXSTA = 4
                read 0,Address
                newaddr = 1
                'Qaaa   (4)
                IF CmdPrefix = "Q" THEN
                        DEC PORTA.4,DEC PORTA.3,DEC PORTA.5,DEC PORTA.2,_
                        DEC PORTE.0,DEC PORTA.1,DEC PORTC.1,DEC PORTC.0,_
                        DEC PORTC.2,DEC PORTE.2,DEC PORTC.3,DEC PORTE.1,_
                        DEC PORTD.2,DEC PORTD.1,DEC PORTD.3,DEC PORTD.0,_
                        DEC PORTC.4,DEC PORTC.5,DEC PORTD.7,DEC PORTD.6,_
                        DEC PORTB.0,DEC PORTD.5,DEC PORTB.1,DEC PORTD.4,13]
                'Paaa   (4)
                if CmdPrefix = "P" then                                                '(PING)    '$BxxxQ
                'Oaaarrs    (7)
                IF CmdPrefix = "O" THEN
                    'Convert Relay from ASCII to DECIMAL    Oaaaoo
                    for x = 4 to 5
                    next
                    Relay = SerBuff[4] * 10
                    Relay = Relay + SerBuff[5]
                    Stat = (SerBuff[6]-"0")
                        if Relay = 1 then
                            if stat = 0 then
                                OUT1 = 0
                                OUT1 = 1
                        if Relay = 2 then
                            if stat = 0 then
                                OUT2 = 0
                                OUT2 = 1
                        if Relay = 3 then
                            if stat = 0 then
                                OUT3 = 0
                                OUT3 = 1
                        if Relay = 4 then
                            if stat = 0 then
                                OUT4 = 0
                                OUT4 = 1
                        if Relay = 5 then
                            if stat = 0 then
                                OUT5 = 0
                                OUT5 = 1
                        if Relay = 6 then
                            if stat = 0 then
                                OUT6 = 0
                                OUT6 = 1
                        if Relay = 7 then
                            if stat = 0 then
                                OUT7 = 0
                                OUT7 = 1
                        if Relay = 8 then
                            if stat = 0 then
                                OUT8 = 0
                                OUT8 = 1
                        if Relay = 9 then
                            if stat = 0 then
                                OUT9 = 0
                                OUT9 = 1
                        if Relay = 10 then
                            if stat = 0 then
                                OUT10 = 0
                                OUT10 = 1
                        if Relay = 11 then
                            if stat = 0 then
                                OUT11 = 0
                                OUT11 = 1
                        if Relay = 12 then
                            if stat = 0 then
                                OUT12 = 0
                                OUT12 = 1
                        if Relay = 13 then
                            if stat = 0 then
                                OUT13 = 0
                                OUT13 = 1
                        if Relay = 14 then
                            if stat = 0 then
                                OUT14 = 0
                                OUT14 = 1
                        if Relay = 15 then
                            if stat = 0 then
                                OUT15 = 0
                                OUT15 = 1
                        if Relay = 16 then
                            if stat = 0 then
                                OUT16 = 0
                                OUT16 = 1
                        if Relay = 17 then
                            if stat = 0 then
                                OUT17 = 0
                                OUT17 = 1
                        if Relay = 18 then
                            if stat = 0 then
                                OUT18 = 0
                                OUT18 = 1
                        if Relay = 19 then
                            if stat = 0 then
                                OUT19 = 0
                                OUT19 = 1
                        if Relay = 20 then
                            if stat = 0 then
                                OUT20 = 0
                                OUT20 = 1
                        if Relay = 21 then
                            if stat = 0 then
                                OUT21 = 0
                                OUT21 = 1
                        if Relay = 22 then
                            if stat = 0 then
                                OUT22 = 0
                                OUT22 = 1
                        if Relay = 23 then
                            if stat = 0 then
                                OUT23 = 0
                                OUT23 = 1
                        if Relay = 24 then
                            if stat = 0 then
                                OUT24 = 0
                                OUT24 = 1
                    HSEROUT [CmdPrefix,DEC3 Address,dec2 Relay,dec Stat,13]
    Junk:
    for x = 0 to 9
        serbuff[x] = " "
    next
    T1CON   = timeron
    May 2008
    Italy
    Default Re: Help guys...communication issue, I think?
    Read this application note. It should help you to solve the problem.
    http://www.analog.com/static/importe...tes/AN-960.pdf
    Cheers
    Al
    Yeah, your tranceiver chips doesn't have a way to disable their drivers.
    When two or more of those are connected to the same pair of wires they will fight each other. I think you want the MAX3080 - not 3081 - then take your TxLED signal and wire it to the DE-pin (HIGH to enable the driver) so that ONLY the board which is actually going to put data on the bus has its driver enabled, all other boards should have their drivers disabled.
    Dec 2005
    Hey Henrik,
    Thanks for your reply. I looked at the Analog datasheet and the only thing that jumped out at me was their termination schema. My bus is built exactly like this one: http://datasheets.maximintegrated.co...80-MAX3089.pdf (page 20). Did I miss something in the datasheet, or is the 3081 only intended for point to point comms? If so, it sure sounds like a board rework is in order huh. bummer.
    Thanks again,
    Chris
    Hi Chris,
    Yes and no..... The actual bus may be built the same but your tranceiver chips (the MAX3081) doesn't have the DE-pin which you see in the schematic on that page and which you need for multidrop networks so yes, the MAX3081 is basically intended for point-to-point.
    If the tranceiver has no way to turn of its driver then it will always drive the bus to one state or the other. Then, when another tranceivers driver is hooked across the same pair of wires and IT too tries to drive the bus to one state or the other there will be a conflict. One tries to drive it high while the other tries to drive it low - for example. On the chips with the DE-pin (Driver Enabled) you can disable the driver outputs all together.
    Dec 2005
    Thanks Henrik,
    Bummer, I was afraid you were going to tell me that I wonder why the 887 board works with both boards on the bus though? That's the part that stumps me. Do you have any insight on that? Just seems that both of them would crash, not just one...
    Chris
    If you're stuck with those drivers, what if the PIC controls power to the drivers? Do they take time to "boot up"?
    Robert,
    The chips are tranceivers...if you power them down they won't be able to receive either.
    The PIC will never get any queries to send any data because the receiver is powered down, you might as well throw out the tranceiver all together... ;-)
    Chris,
    Can't say why it appears to work in some situations. Perhaps one driver is slightly "stronger" than the other (don't think so though).
    Dec 2005
    Hey guys,
    I actually did give the power down thing a thought for a moment, but as Henrik pointed out...1 step forward, two steps back
    No problem on the mysterious 887 board operation, as I'm reworking the boards now. I do, however, have one more quick question for ya Henrik... I should be ok to still run the MAX3081 on the 232 to 422 master board, correct? My thought is, I shouldn't need to (or wouldn't want to) enable or disable the Rx and Tx lines at the master... Is my thinking correct on that one?
    BTW: The new boards will have the MAX3086 on 'em, of course with the sacrifice of my heartbeat led output Oh well, small price to pay.
    Thanks again guys,
    Chris
    Hi Chris,
    Lets stop and think about that for a minute....
    Finished thinking?
    If ANY one of the drivers on the bus (doesn't matter which one) is enabled it will "occupy" the bus. There can only be ONE enabled driver on the bus at any given time or they will end up fighting each other.
    All receivers on all devices shouls be enabled at all times. The transmitter on each device should be enabled when, and only when, that specific device is about to put data onto the bus. If two or more transmitters are enabled at the same time there will be conflicts.
    EDIT: OK, hold on, brainfart on my behalf here. You're running full duplex so please disregard the above. Yes, you can keep the transmitter on the RS232<->RS422 converter enabled all the time. Doh.....
    Dec 2005
    Cool Henrik,
    I have to say that your brainfart wasn't near as big as mine! Doh, I designed, built and stuffed the boards with those 3081's Oh well, ya gotta crack a few eggs to make an omelet right... I'll check back with progress when I get the new boards whipped up.
    Thanks a ton,
    Chris
    Have you read this?
    http://www.picbasic.co.uk/forum/showthread.php?t=17282
    I was able to have a master PIC talk to multiple slave PICs at 115200. The trick is to have slaves enable usart transmit only when spoken to by the master.
    I assigned each slave an ID (used in the data stream). The master would wait for a reply when necessary or keep on working.
    A calling-all-slaves ID can be used to have them all do something, but they can't reply.
    So no need for any comm IC, just straight PIC to PIC connections.
    Dec 2005
    Hey Robert,
    I actually did try that trick in my posted code above, but I just revisited it just to make sure and bummer...no love If you can take a glance at my code above and double check the technique I used, that would be awesome. Heck, maybe I'm not using it correctly?
    Thanks again,
    Chris
    Check the code for slaves in this post:
    http://www.picbasic.co.uk/forum/show...809#post116809
    That's all I needed to do. Master TX to slave RXs, slave TXs to master RX, I think I had pull-ups at master.
    I'm having a hard time with your code (sick, not feeling right).
    I'd suggest making a copy of your program and strip everything except USART logic. Then post that stripped code if you have problems.
    Keep it simple; talk to slave 1, wait for reply, talk to slave 2, wait for reply.
    You can also use a MAX232 and listen in with your PC and see exactly what is sent. That helped me a lot.
    Chris,
    You can't use Roberts aproach since you DO have the tranceiver chip in between the PIC and the bus. It doesn't matter if you turn of the USART TX in the PIC, the driver in the tranceiver chip will still be enabled and will still "hold" the line.
    Since Robert does NOT have any tranceiver chip in between the PIC and the "bus" turning of the USART TX (ie making its pin high impendence) is effectively the same as what you need to do with your tranceiver chip (turning off the transmitter that is).
    If your application invloves any sort of distances and/or deployement in the "real world" I'd definitely stick with some kind of bus like you have now. I wouldn't want to expose the PICs inputs/outputs directly to tens or hundreds of metres wires acting as antennas. Of course YMMV.
    Dec 2005
    Thanks guys,
    I have succumbed to the fact of the board rework. Bummer for sure. 1 more question...I have looked at so many datasheets for transceivers that I have lost track. On some datasheets it shows the termination resistor on both the Tx and Rx endpoints, and on others it shows it only on the Rx endpoints? I suppose that was more of a statement rather than a question, but you guys get where I'm going with it... I've got my Rx endpoints terminated now...Am I good with that? Don't want to rework twice.
    Thanks guys,
    Chris
    ***Little deja vu here http://www.plcforum.it/f/topic/79753...422-multidrop/
    Hi Chris,
    There's a section specifically covering bus termination in the .pdf linked to earlier, it covers the differences.
  1. Replies: 5
    Last Post: - 25th May 2013, 17:33
  2. Replies: 16
    Last Post: - 1st March 2013, 09:22
  3. Hey guys, will this work?
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 14:48
  4. guys pls help me in mp lab
    By darylbrown2005 in forum mel PIC BASIC
    Last Post: - 9th March 2009, 17:58
  5. Guys pls let me know
    Last Post: - 8th March 2009, 20:49
