2x16 LCD Graphics :)
Results 1 to 40 of 52
    Aug 2003
    Default Re: 2x16 LCD Graphics :)
    One more:
    Last edited by Demon; - 13th October 2013 at 16:07. Reason: video removed at user's request - Robert
    Sao Paulo - Brazil
    Impressive ! .... Really.
    Very!
    Aug 2003
    Thanks Guys,
    I am having some trouble with diagonal lines and circles.
    When you use a real gfx display with PBP, is it usually the display that
    handles the lines and circles, or is it done in PBP?
    I'm finding the algorithms are usually in C, and all seem to want to look
    for values below zero (signed integer variables), where one of these
    variables would wrap back to 0xFF if you decremented from zero using PBP
    For the only diagonal lines in the video, I was able to do a trick and
    check a value is above #128, pretending that value is zero.
    This is so far only working if the destination point of the line has higher
    x and y coordinates than the start point..
    (ie. I can draw a line at any angle from x-0,y-0, to anywhere).
    Here is the difference in the code.
    x0 = 3 : y0 = 3
    x1 = 21 : y1 = 11
    gosub drawline
    drawline:
    	stepx = 0
    	stepy = 0
    	frac = 0
    	'a line is x0,y0 to x1,y1.
    	dy = y1 - y0
    	dx = x1 - x0
    	IF dy > 128 THEN
    	dy = dy - 1
    	stepy = stepy - 1
    	stepy = 1
    	IF dx > 128 THEN
    	dx = dx - 1
    	stepx = stepx - 1
    	stepx = 1
    	dy = dy << 1
    	dx = dx << 1
        'draw pixel
    	px = x0 : py = y0
    	gosub setpixel
    	IF (dx > dy || dx > 128) THEN
        frac = dy - (dx >> 1)
        WHILE x0 != x1
        IF (frac < 128) THEN
    	y0 = y0 + stepy
     	frac = frac - dx
        x0 = x0 + stepx
        frac = frac + dy
        'draw pixel
      	px = x0 : py = y0
    	gosub setpixel
        WEND
        frac = dx - (dy >> 1)
        WHILE y0 != y1
    	x0 = x0 + stepx
    	frac = frac - dy
        y0 = y0 + stepy
        frac = frac + dx
        'draw pixel
    	px = x0 : py = y0
    	gosub setpixel
        WEND
    ... and the original C
    static void drawLine(int x0, int y0, int x1, int y1, int color, Color* destination, int width)
    	int dy = y1 - y0;
    	int dx = x1 - x0;
    	int stepx, stepy;
    	if (dy < 0) { dy = -dy;  stepy = -width; } else { stepy = width; }
    	if (dx < 0) { dx = -dx;  stepx = -1; } else { stepx = 1; }
    	dy <<= 1;
    	dx <<= 1;
    	y0 *= width;
    	y1 *= width;
    	destination[x0+y0] = color;
    	if (dx > dy) {
    		int fraction = dy - (dx >> 1);
    		while (x0 != x1) {
    			if (fraction >= 0) {
    				y0 += stepy;
    				fraction -= dx;
    			x0 += stepx;
    			fraction += dy;
    	} else {
    		int fraction = dx - (dy >> 1);
    		while (y0 != y1) {
    				x0 += stepx;
    				fraction -= dy;
    			y0 += stepy;
    			fraction += dx;
    I wonder what of the C compilers that are for 16F pics.
    Maybe they don't do signed integers either?
    If I could compile the original C source in a pic C compiler,
    and then disassemble it, I could have the result in RISC asm.
    Bombay, India
    In a real graphic LCD, it is the user who draws the lines / circles using Bresenhams algorithm or a variant. PBP, C or ASM is just a matter of choice.
    I am curious to know why you want to use a character lcd this way other than for the thrill of doing it. You only get 8 programmable characters which is about a 4th of the 16x2 display. Your demos too show repeated patterns. It is much more challenging and fun to get a graphic lcd come upto video speed (20fps and more).
    Aug 2003
    It is for the thrill.. and I figure the work is not wasted, because these LCDs do still get use.
    I already did an LED matrix display with games, scroller etc., and I don't think it is getting any faster.
    Also, I have not written for pics in some time, and needed something to get going.
    There is room to duplicate the graphics screen, but for a practical application,
    I figure the rest of the screen would have some text on it.
    I have solved the line drawing, but if you have a way to draw circles in PBP it
    would be appreciated At the moment my circles are perfect squares of the
    correct radius, but I'm keeping that for squares since it beats defining all the corner coordinates
    I would not buy a gfx LCD if I couldn't do the graphics, so it's a good way to come up with
    the routines now. I would still like to do my own hardware/software mapping GPS one day.
    I do plan to give it away when it's finished and cleaned up.
    ps to mods, it would be great if you could delete every video posted here
    (can seem to delete/edit my posts)
    I've done the C-64/Amiga style Megademo
    Videos removed.
  1. Need advice with LCD 2x16
    Last Post: - 26th April 2011, 07:58
  2. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 05:46
  3. graphics lcd with lcdout style serial??
    By reaper0995 in forum Serial
    Last Post: - 27th March 2008, 20:57
  4. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
  5. OT: KS0108 Graphics LCD control question
    By Archilochus in forum General
    Last Post: - 18th December 2004, 19:23
