2x16 LCD Graphics :)
Page 1 of 2 12 LastLast
Results 1 to 40 of 52
    Aug 2003
    Default 2x16 LCD Graphics :)
    Hi Guys,
    I know the odometer effect has been done, also the bargraph,
    but both use single isolated custom chars as up to eight screen buffers drawn all over the place.
    Has anyone considered making a frame buffer array in RAM, and then copying out
    the bytes to all of the eight custom characters for every frame?
    It's probably five years too late with the price of gfx LCDs now,
    but I think a nice exercise, and think the rotating 3D cube is doable.
    I was thinking do a real 23x17 frame buffer, and just accept that the
    inbetween lines are invisible pixels, so long as the display is animated.
    Most of the points on the cube are duplicates of another with different initial 2D offsets.
    I can't do the point rotation without trig, but can use another program to generate the
    pre rotated list of points of 36 or so different angles around each axis.
    The lines should be right to draw locally since they only need square root.
    Also proper balls bouncing off walls at inverted angles should be ok locally.
    Pixel resolution horizontal scrolling should be also possible on an 8x1 display.
    Any ideas suggestions? Has someone done this?
    Aug 2003
    Default Re: 2x16 LCD Graphics :)
    Having to send the command to change lines halfway though the drawing is a tragedy,
    and so is setting the LCD home, but the latter doesn't interrupt drawing halfway through.
    It would be better to waste the same amount of time between sending every character.
    Aug 2003
    Ok, now I can set pixel coordinates, and no longer have to think about custom characters
    It was hard because each line for a custom char is still a byte, but only five bits of it are used,
    and the LCD wants them in the least significant bits, but my framebuffer is a continuous stream of bits.
    I'll try the line drawing, and calculating proper angles for balls.
    A smaller (single pixel) ball works better in the small space, but didn't make for a good video.
    Last edited by Demon; - 13th October 2013 at 16:08. Reason: video removed at user's request - Robert
    Aug 2003
    Line drawing (almost) :
    Last edited by Demon; - 13th October 2013 at 16:07. Reason: video removed at user's request - Robert
    Aug 2003
    One more:
    Sao Paulo - Brazil
    Impressive ! .... Really.
    Very!
    Aug 2003
    Thanks Guys,
    I am having some trouble with diagonal lines and circles.
    When you use a real gfx display with PBP, is it usually the display that
    handles the lines and circles, or is it done in PBP?
    I'm finding the algorithms are usually in C, and all seem to want to look
    for values below zero (signed integer variables), where one of these
    variables would wrap back to 0xFF if you decremented from zero using PBP
    For the only diagonal lines in the video, I was able to do a trick and
    check a value is above #128, pretending that value is zero.
    This is so far only working if the destination point of the line has higher
    x and y coordinates than the start point..
    (ie. I can draw a line at any angle from x-0,y-0, to anywhere).
    Here is the difference in the code.
    x0 = 3 : y0 = 3
    x1 = 21 : y1 = 11
    gosub drawline
    drawline:
    	stepx = 0
    	stepy = 0
    	frac = 0
    	'a line is x0,y0 to x1,y1.
    	dy = y1 - y0
    	dx = x1 - x0
    	IF dy > 128 THEN
    	dy = dy - 1
    	stepy = stepy - 1
    	stepy = 1
    	IF dx > 128 THEN
    	dx = dx - 1
    	stepx = stepx - 1
    	stepx = 1
    	dy = dy << 1
    	dx = dx << 1
        'draw pixel
    	px = x0 : py = y0
    	gosub setpixel
    	IF (dx > dy || dx > 128) THEN
        frac = dy - (dx >> 1)
        WHILE x0 != x1
        IF (frac < 128) THEN
    	y0 = y0 + stepy
     	frac = frac - dx
        x0 = x0 + stepx
        frac = frac + dy
        'draw pixel
      	px = x0 : py = y0
    	gosub setpixel
        WEND
        frac = dx - (dy >> 1)
        WHILE y0 != y1
    	x0 = x0 + stepx
    	frac = frac - dy
        y0 = y0 + stepy
        frac = frac + dx
        'draw pixel
    	px = x0 : py = y0
    	gosub setpixel
        WEND
    ... and the original C
    static void drawLine(int x0, int y0, int x1, int y1, int color, Color* destination, int width)
    	int dy = y1 - y0;
    	int dx = x1 - x0;
    	int stepx, stepy;
    	if (dy < 0) { dy = -dy;  stepy = -width; } else { stepy = width; }
    	if (dx < 0) { dx = -dx;  stepx = -1; } else { stepx = 1; }
    	dy <<= 1;
    	dx <<= 1;
    	y0 *= width;
    	y1 *= width;
    	destination[x0+y0] = color;
    	if (dx > dy) {
    		int fraction = dy - (dx >> 1);
    		while (x0 != x1) {
    			if (fraction >= 0) {
    				y0 += stepy;
    				fraction -= dx;
    			x0 += stepx;
    			fraction += dy;
    	} else {
    		int fraction = dx - (dy >> 1);
    		while (y0 != y1) {
    				x0 += stepx;
    				fraction -= dy;
    			y0 += stepy;
    			fraction += dx;
    I wonder what of the C compilers that are for 16F pics.
    Maybe they don't do signed integers either?
    If I could compile the original C source in a pic C compiler,
    and then disassemble it, I could have the result in RISC asm.
    Bombay, India
    In a real graphic LCD, it is the user who draws the lines / circles using Bresenhams algorithm or a variant. PBP, C or ASM is just a matter of choice.
    I am curious to know why you want to use a character lcd this way other than for the thrill of doing it. You only get 8 programmable characters which is about a 4th of the 16x2 display. Your demos too show repeated patterns. It is much more challenging and fun to get a graphic lcd come upto video speed (20fps and more).
    Aug 2003
    It is for the thrill.. and I figure the work is not wasted, because these LCDs do still get use.
    I already did an LED matrix display with games, scroller etc., and I don't think it is getting any faster.
    Also, I have not written for pics in some time, and needed something to get going.
    There is room to duplicate the graphics screen, but for a practical application,
    I figure the rest of the screen would have some text on it.
    I have solved the line drawing, but if you have a way to draw circles in PBP it
    would be appreciated At the moment my circles are perfect squares of the
    correct radius, but I'm keeping that for squares since it beats defining all the corner coordinates
    I would not buy a gfx LCD if I couldn't do the graphics, so it's a good way to come up with
    the routines now. I would still like to do my own hardware/software mapping GPS one day.
    I do plan to give it away when it's finished and cleaned up.
    ps to mods, it would be great if you could delete every video posted here
    (can seem to delete/edit my posts)
    I've done the C-64/Amiga style Megademo
    Videos removed.
    Aug 2003
    Thanks Robert, I combined everything into one retro demo:
    I robbed the circle drawing from a GLCD code sample here, and added a bit more.
    There are 10 sections to the demo, but they only last a few seconds each.
    The trick at the end is what I should have started with to trick people to thinking
    I had the entire display
    It is almost ready to go, I just have to make sense of the source for others.
    Last time I released a project, there were three different revisions of matching
    hardware and software improvements with schematics,
    and although others got it working, it caused confusion, and years of follow up for me.
    Being mindful of that this time round, the schematic is in the PBP manual
    The only differences are this is a 16F628A (instead of 16F84/A in the manual),
    the LCD backlight is powered by the pic (RB6) for the strobe effect in the video,
    and the pic is driven with an 8MHz crystal to match the speed in the video.
    The clock speed is not critical though.
    The serial Rx pin in the familiar looking diagram is not implemented.
    If you make a board for this, it's still tentative.
    LCD R/W pin may need to be accessed later, so it might pay to wire
    it to somewhere accessible before wiring it to ground to mod later
    (I heard you can rip all of the character graphics from the LCD itself).
    It should also get a couple of buttons.
    Cheers, Art.
    WARNING: Video may trigger epyleptic seizure in some viewers.
    Use 3D glasses under welding goggles as protection.
    Awesome stuff Art.
    Aug 2003
    Here it is:
    http://www.freewebs.com/defxev/LC2D.zip
    Interestingly... I realised this is one of the two LCDs I bought off Melanie here ages ago:
    http://www.picbasic.co.uk/forum/show...=2298#post2298
    Funny that. There was not much fancier at the time, but now the options are endless.
    I always get that last little nice feature working AFTER the distribution
    Pretty fancy stuff there Art, He He Imagine that display on the bank's ATM machine, make a good video.
    Aug 2003
    Forgot this:
    Credit to Centrex of Whirlpool forum (Australia).
    Suitable for this, and whatever logging LCD circuit based on the PBP manual LCDOUT example circuit.
    I will do a more bare source code, more intended for people using their own programs,
    and am also getting an 8x1 or 8x2 LCD so I either get a whole line or a whole display to work with.
    The reason being, I hear by connecting the LCD R/W line to an IO pin, you can access the
    LCD's CGROM, and rip the character set. That would be great for the pixel perfect text scroller.
    Up until now, the character data has been stored on EEPROM or on-chip EEPROM for these sort of tricks.
    You are kidding me, right?
    Unbelievable graphics on this LCDs!!! Wow, Art. Supercalifragilisticexpialidocious!
    Aug 2003
    Happens every time on every platform.
    I suggest, if you would like some cool new feature in a program you write,
    that you upload a distribution, and give it away to the public.
    Then within a day or two, you have changed the way you think about it,
    and have a moment of insight Oh, and the implementation is a breeze also.
    CONGRATULATIONS ART:
    You have been featured on Hackaday
    http://hackaday.com/2013/10/16/teach...s/#more-105170
    Congrats Art!
    Jan 2012
    Grid EN19MV
    Been following this thread with interest. Congrats on an awesome job AND your HackaDay feature!
    -Stephen Hawking
    Aug 2003
    Thanks Guys
    I finally joined their forum, they would have got it from that.
    I've been watching H-A-D for years... certainly some interesting stuff.
    My 144 LED game ended up there too back when I was doing that.
    Anyways that'll be some nice traffic for ya!
    It makes me wish I'd waited tho
    I'll have to do a version 2.
    Aug 2003
    Changes for LC2D Version 2 - 18/10/13
    Base code:
    Reduced program memory, and RAM consumption
    (approximately ten more bytes of RAM are freed).
    This leaves more RAM in BANK0 for the user program.
    Performance win on base code
    (first version is still on the site for comparison).
    When the demo program is removed,
    there's much more resource for your program.
    Demo User Program:
    Extra resource freed by improved base code is consumed
    by the new demo. Now has fifteen demo sections!
    The first demo sections are identical, except that the first
    demo section inverts the LCD on it's first cycle for LCD test.
    The new demo sections expand on a trick appearing to
    control the entire LCD display when run on a 2x16 LCD.
    Fixed graphic invader animation frame B sprite (legs).
    Classic Rolling Odometer Effect
    One of the new demo sections is the rolling odometer
    effect that also moves around the display.
    It looks like a penalty, but is not. It's delayed because it
    is the most prone to messing up the display with lag trails
    when run on slow LCDs such as the one in the video.
    The user program doesn't have to move it around,
    or delay any sprite drawing routines.
    I ran out of memory in the process of making it able
    to reverse direction properly for counting backwards.
    Currently, the variable must be incrementing by one.
    New Notes:
    Pic run at 8MHz telling PBP compiler it's running at 4MHz
    results in only 600ms pause time for LCD start up delay.
    PBP manual suggests PAUSE 1000 delay to accomodate
    slower starting LCDs. If your LCD doesn't start, change to
    PAUSE 2200 before compiling the program, or insert the
    pic into the socket after powering the circuit with the LCD.
    Sloppy bounds checking on demo user program demonstrates
    crash proofing in base code. The user program is allowed to
    draw off screen. Base code does not check bounds on the
    individual X,Y coords, rather that their calculated destination
    in the first frame buffer is within bounds of the array.
    Crazy shape or line drawing could still have consequence.
    I don't know what those routines will do in unusual circumstances.
    http://www.freewebs.com/defxev/LC2D.htm
    Enjoy
    Aug 2003
    I had to write an iPhone simulator App to do the vector rotation on the 3D cube but got it:
    It takes sixteen bytes per frame to store a list of coordinates in lookup tables
    not compressed in any way. The pic still has to look up the points, and draw lines between them.
    This makes a more simple to understand user program.
    Now it's produced, it's very simple. The pic program just looks up sixteen bytes and
    draws lines between those coordinates for every frame. I took out anything fancy.
    If you calculate vector rotation on another platform is it still 3D graphics?
    Aug 2003
    3D Point Rotation Demo:
    Who said you only get eight custom characters?
    LCD Freedom - World's First HD44780 POV!
    Apr 2007
    Pennsylvania, USA
    Wow, awesome job Art! Quite impressive!
    Shawn
    Aug 2003
    It took a 20MHz clock to control the entire display, with all four cubes different,
    but I could make videos forever
    Since the video framerate is not synced to the pic's clock in any way,
    and therefore the LCD backlight strobe frequency, it looks better here than the video comes up.
    Aug 2003
    Normally, Noritake will provide you with a dot matrix VFD sample to play with,
    but only if you live in US or Canada:
    http://www.noritake-elec.com/evalkit-sample.php
    That's really quite nice, so ppl should be aware of that.
    Suspecting that POV will work great with VFD, I promised a great demo including
    their logo, in return for them sending me some 2x16 character modules.
    They have replied with a suggestion display which is a HD44780, so it looks good
    I don't think I'm finished with them.
    I think it's possible to do greyscale graphics on a monochrome dot matrix VFD.
    Feb 2005
    Kolkata-India
    I didn't find the source for your AWESOME 2D LCD Graphics on the link you provided. I do not do PBP much nowadays but your demo is so cool, I want to try it out.
    Cheers
    Sougata
    Aug 2003
    Freewebs canned my free web hosting.
    If you pm me an email address I’ll send it.
    Cheers, Art.
    Feb 2005
    Kolkata-India
    Cheers, Art.
    Your Forum Inbox seems to be full. PM not going through.
    Sougata
    Aug 2003
    Sorry, it should be ok now.
    Feb 2005
    Kolkata-India
    https://www.youtube.com/channel/UCTc...EQ-LRACW8CRh-w
    Cool, great videos
    Sougata
    Aug 2003
    Email sent...
    Also trying attachment on this forum.
    LC2D-V2.zip
    Aug 2003
    I’ve been having another play with it, in C, but nothing that can’t be done the same way in PBP.
    For example to push the cubes off the screen, just count every six movements of a cube and increment the number of spaces following it.
    Then you also have the value of the screen position to follow the graphics with text.
    The graphics is slowed for debugging. It’s something I don’t want to have to wait for when it’s done.
    I don’t like to reuse code without adding something to it, so I’m going for a wall of cubes that the LCD window can move around in.
    They only have to move up and down as well as sideways.
    Also, for the project, I would like to display practical information with graphics (such as a Moon phase), and be able to slide the
    graphics area into the display in a fluid motion from any direction.
    I scrolled the text vertically to begin with, but am now thinking toward scrolling in two fields sideways
    with the graphics display in front and stopping for a while when everything is in position, and then scrolling off again.
    Aug 2003
    Whoops.. the video above is deleted and I can’t edit the post.
    https://www.youtube.com/my_videos?o=U
    LOL
    I see my own videos with that link.
    Aug 2003
    whoops!
    LOL
    Aug 2003
    The current thing I’m working on with it is a transition from one text screen to another.
    In the next frame or two when the A is completely gone from the screen,
    it can be replaced by either a space or the new text, and doesn’t need to be
    using a custom character location anymore. Then that location freed by the A,
    can be used by the G, or whatever the next character to move is, until all text is gone or replaced.
    It does mean I have to type a lot of crap to define all of the character set in program memory tho.
    So far I’ve done the symbols and up to the numeral 0
    Here’s a demo I did with dsPic... much of it is a little too much for the display to look good, but I still wanted to see it
    Aug 2003
    Got it It works a little differently to the graphics library.
    A little harder then I thought, but maybe it can be guessed how it’s done.
  1. Need advice with LCD 2x16
    Last Post: - 26th April 2011, 07:58
  2. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 05:46
  3. graphics lcd with lcdout style serial??
    By reaper0995 in forum Serial
    Last Post: - 27th March 2008, 20:57
  4. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 21:37
  5. OT: KS0108 Graphics LCD control question
    By Archilochus in forum General
    Last Post: - 18th December 2004, 19:23
