If the device is mains powered there's a 50/60Hz clock on the transformer secondary
the way old LED digital clocks used to keep time from mains signal.
If you are looking at that with a pic that has an independent clock the results will vary.
If you can run an ADC from internal RC clock
and the pic from xtal, and look at any clock or output signalCode:DEFINE ADC_CLOCK 3
generated by the pic program with ADC the results will differ as clocks lose sync.
I would try the resistor Cap network first (timing cap discharge via resistor).
