Random outcome on multiple devices
Results 1 to 23 of 23
    Aug 2003
    Default Re: Random outcome on multiple devices
    I can't help thinking there would be some noise on the power you'd see with ADC.
    Interference between ADC pins has always been a problem...
    Jan 2011
    Sydney, Australia
    I am not sure how I would go about un-tapping the noise to produce a random output.
    Would you care to expand your idea for me?
    Cheers
    Barry
    VK2XBP
    Aug 2003
    If the device is mains powered there's a 50/60Hz clock on the transformer secondary
    the way old LED digital clocks used to keep time from mains signal.
    If you are looking at that with a pic that has an independent clock the results will vary.
    If you can run an ADC from internal RC clock
    DEFINE ADC_CLOCK 3
    and the pic from xtal, and look at any clock or output signal
    generated by the pic program with ADC the results will differ as clocks lose sync.
    I would try the resistor Cap network first (timing cap discharge via resistor).
    (Never done this)
    What about reading a resistor on analog pin? A high value, maybe 100K, would that produce a reasonably wide range of seeds?
    Edit: since no 2 resistors are exactly alike, the voltage should vary.
    Aug 2003
    It sounds like it would work.
    That would be the first thing I'd try now, nice one.
    .. and if not, then tapping the centre of a divider (two resistors from +ve to Gnd).
    Still cheaper than timing a cap discharge.
    I can't say I've tried to make two devices produce a different result,
    just one device from one launch to the next.
    (Never done this)
    Even better, use a LED and 330R resistor. You're bound to get different voltages and it serves as a power indicator.
    Jan 2011
    Sydney, Australia
    Hi Guys,
    All great ideas - thank you.
    I have decided to program each PIC separately making subtle differences to LED flash rates and "off-time" periods to give an overall effect of randomness.
    This is a one-off project that I am doing as a labour of love for my company. As such, I just want to get in and get out as quickly as possible
    Cheers
    Barry
    VK2XBP
    One possible issue with using the ADC is that the 12F508 being mentioned in the first post doesn't have one....
  1. Programming multiple pics with multiple programs
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 17:47
  2. Multiple I2c Devices
    By alphaengr in forum mel PIC BASIC Pro
    Last Post: - 12th January 2012, 04:37
  3. Multiple serial devices to one pic
    By rshaver in forum mel PIC BASIC Pro
    Last Post: - 16th October 2011, 15:34
  4. 12F683 ADcin = binary outcome!
    Last Post: - 5th March 2010, 04:42
  5. Self update of devices
    By Ioannis in forum General
    Last Post: - 24th December 2009, 17:49
