need serial 20x4 lcd code example
Results 1 to 10 of 10
    Oct 2013
    Default Re: need serial 20x4 lcd code example
    Here is my code:
    pause 1000 ' wait for the LCD to startup
    serout PortA.0,0,[$FE,$01] ' clear the screen
    serout PortA.0,0,["Hello world !"] ' send string “Wherever you go”
    serout PortA.0,0,[$FE,$C0] ' move the cursor to the 2nd line
    serout PortA.0,0,[" Here we are "] ' send string “ there you are ”
    pause 1000 ' pause for a second
    goto main ' loop
    Picture what i see is bellow.
    Name:  serial 16x2 and 20x4 problem.jpg
    Sep 2010
    Las Vegas, NV
    I don't see your configs or defines. That's usually where the issue lies.
    This linkhttp://www.picaxe.com/docs/axe134.pdf has a test program. Did that work?
    Last edited by AvionicsMaster1; - 7th October 2013 at 16:53. Reason: eliminated stupid comments by me
    Miami, Florida USA
    Saulius,
    That has been done before by Darrel. Check this link
    http://www.picbasic.co.uk/forum/show...=2388#post2388
    Anonymous
    Oct 2013
    It works fine with picaxe 08M2 and 20X2 i use. Also ok in parallel mode with pic. Only a problem conecting 20x4 to pic16f628a or 877a in serial.
    For 16x2 i do not use any config or define settings and it works ok. Maybe you know what settings shoud i try??
    Sep 2010
    Las Vegas, NV
    Have you tried
    serout PortA.0,4,[$FE,$01] ' clear the screen
    serout PortA.0,4,["Hello world !"] ' send string “Wherever you go”
    serout PortA.0,4,[$FE,$C0] ' move the cursor to the 2nd line
    serout PortA.0,4,[" Here we are "] ' send string “ there you are ”
    goto main ' loop
    Sep 2010
    Las Vegas, NV
    Just curious if that actually worked?
  1. Pic18f452 with 20x4 LCD Help
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 22:43
  2. 20x4 LCD and P18F2680
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 9th June 2006, 19:26
  3. Serial GPS to 20x4 LCD via PIC16f628-04
    By Almightyrastus in forum mel PIC BASIC Pro
    Last Post: - 8th May 2006, 22:35
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
  5. LCD 20X4 connect with DS1820
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 9th March 2005, 11:04
