Need help - 16f876 - strange results
Results 1 to 3 of 3
    Jul 2012
    Unhappy Need help - 16f876 - strange results
    All,
    I am trying to build a simple robot for my daughter and have run into a snag. The code seems to run normal for some time then it will just stop and the hserout command will just start displaying 111111 or 222222 or 33333 over and over again. Every time I reset, it runs for a while and then displays 1 number higher, but over and over again. I am including the code below.
    Of note, when this program is running, I can hear the ultrasonic ping sensor happily pinging away, but once it starts displaying the number repeatedly, everything stops, including the blinking LED and the ping sensor, only the hserout keeps repeating the number.
    I am using a HS setting and disabling the WDT, Brown out, and power up timer.
    define OSC 20
    DEFINE  HSER_BAUD 9600
    TRISC     = %00000000  'All C's are outputs
    TRISB     = %00100000  'All B's are outputs except b5
    CCP1CON   = %00001100  ' Mode select = PWM1
    CCP2CON   = %00001100  ' Mode select = PWM2
    TRIGGER var PortB.4
    ECHO var PortB.5
    IN1 VAR PortC.3
    IN2 VAR PortC.4
    IN3 var PortC.5
    IN4 var PortB.1
    'i var byte
    'duty var byte
    RAWDATA var word
    inINCHES var word
    low IN1
    low IN2
    low IN3
    LOW IN4
    HSEROUT ["Starting", 10, 13]
    MAIN:
    HSEROUT ["GOSUB PING first entry", 10, 13]
    gosub PING
      IF inInches <= 9 THEN Obstacle
      high IN1
      high IN3
      hpwm 1, 250, 2000    ' Forward left motor
      hpwm 2, 250, 2000 ' Forward right motor
    goto MAIN
    Obstacle:                 ' Backwards
     HSEROUT ["backing up", 10, 13]
     low IN1
     low IN3
     while inInches < 12
        high IN2
        high IN4
        hpwm 1, 150, 2000
        hpwm 2, 150, 2000
        gosub Ping
        wend
        low IN2
        LOW IN4
    PING:
     pulsout TRIGGER, 5
     PUlsin ECHO, 1, RAWDATA
     inINCHES = RAWDATA / 74
     hserout ["RAWDATA ",DEC RAWDATA, 10, 13]
     hserout ["inINCHES ",DEC inINCHES, 10, 13]
    Default Re: Need help - 16f876 - strange results
    Ok only thing I see
    Obstacle is a subprogram and you are getting there from a then goto so return does not do what you are asking.
    try IF inInches <= 9 THEN gosub Obstacle
    Apr 2011
    Welches, Oregon
    I am not so experienced as others here, but would offer what help and encouragement that I may. It is my experience that coding never fails, some outside factor is introducing change. Odd behavior is often a power issue. Is your power well suppled? Does the pwm continue during the problem? I did not see configuration; could it be watchdog, a poor ground or other exteral condition?
  1. Strange results with PBP3 and instant interrupts
    By R.G.Keen in forum mel PIC BASIC Pro
    Last Post: - 13th December 2011, 14:57
  2. RC - connection using RCTime produces strange results
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 16:16
  3. Strange Results in Math
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 07:09
  4. Help! - Very strange results with ShiftIn/ShiftOut
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2005, 22:21
  5. First test program, but strange results
    By bartman in forum General
    Last Post: - 19th November 2004, 03:14
