Mounting LEDs ideas?
Results 1 to 5 of 5
    Apr 2011
    Default Re: Mounting LEDs ideas?
    You can purchase LED spacers that are (effectively) x-shaped bottom parts with a flat disc on the top having two holes for the leads. The 'x' part is closest to the PCB/track but gives access to the copper tracks as the leads are 'exposed' down the channels formed by the 'x'....
    Not sure of the available heights but you could use a standard spacer on TOP of the x-shaped one.....
    Farnell do these x-shapes (amongst others) - their part number is 1325971 - check their website.
    Miami, Florida USA
    Also, I have seen some people twisting the LED leads 90 degrees so they can solder the LED on two PCB pads with no holes. I'm not sure that's the best way to do it, but it works.
    Anonymous
    Dec 2010
    Why not simply specify plate through holes then solder from the top?
  1. IR Learner? Need ideas
    Last Post: - 13th April 2011, 23:40
  2. Project ideas 2
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th February 2011, 18:59
  3. Project ideas
    Last Post: - 12th May 2010, 00:34
  4. Multitasking Ideas
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 15th April 2009, 08:50
  5. Any ideas on how to accomplish this?
    By bartman in forum General
    Last Post: - 27th January 2007, 01:48
