Customers Performing Own Upgrades. How Hard Can It Be?
Results 1 to 20 of 20
    Default Re: Customers Performing Own Upgrades. How Hard Can It Be?
    Sorry I don't follow, do you use the MFM in your app?
    I can see why you are unwilling to port to another PIC but the downside of using CDC is substantial.
    An alternative might be to add USB hardware to make a HID connection.
    George
    Apr 2011
    Kent, UK
    ... do you use the MFM in your app?
    Eventually we would use it in future products requiring customer upgrades. At present it's a return to base upgrade.
    I would like to get the *6K22 working first!
    Miami, Florida USA
    For a tipical individual that wants to upgrade the programming in their PIC, I don't think the Microchip Bootloader program would be that complicated for him. If you create a good tutorial with pictures on how to use the Microchip Bootloader, I think that that's the way to go.
    Anonymous
    @rsocor01 I suspect that the target user wouldn't know a PIC from a pick.
    @timmers There are many PIC devices similar to *6K22 with USB builtin but I suspect you have already decided against porting. In which case CDC must look very attractive but I would suggest falsely so. Just a couple of ways that you can have HID, a cheap PIC with USB as a buffer or maybe MCP2210. BTW you do realize that USB bootloader is purely software.
    Anyways, I leave you with this thought - CDC bad, HID good.
    George
    Perhaps I'm missing something. :?
    Can you not supply or advise your customers to buy a cheap pic programmer and simply send them hex files.
    The hex files could be zipped and password protected if required on an individual customer basis.
    http://www.piccircuit.com/shop/pic-p...rogrammer.html
    That's what I do. Same pic programmer covers all of my projects/products.
    Even some very elderly punters have been able to cope with using pickit2 and the programmer.
    Perhaps it's possible to use pickit 2 in a command line mode with file name in the script.
    Yes you are. He's trying to find a method for a non-technical person to upgrade a "black box", to repeat myself - I suspect that the target user wouldn't know a PIC from a pick.
    George
    Sep 2009
    MikroE have nice little hid bootloader.
    http://www.mikroe.com/img/developmen...der_window.jpg
    It would be nice to have open source bootloader like that in PBP.
  1. PBP and a hard dirve?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 26th February 2014, 20:13
  2. Field code upgrades - how to do it?
    Last Post: - 20th September 2010, 20:40
  3. Performing a loop every 10ms
    By wasssup1990 in forum mel PIC BASIC Pro
    Last Post: - 15th February 2008, 11:31
  4. HPWM the hard way
    By markk5xh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2008, 22:02
  5. hard disk and PBP
    By ely in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 03:16
