Newbie migrating from Basic Stamp to PIC
Results 1 to 8 of 8
    Default Re: Newbie migrating from Basic Stamp to PIC
    Or you could use simulation, Proteus, Oshonsoft etc. You draw your circuit diagram in the application and this creates a model in which the simulator allows you do do all your single stepping, variable monitoring, breakpointing etc. etc. The downside is cost and whatever imperfections are in the simulator, the upside is pretty good and will over a period recover some or all of that cost. A short list of the positives - no development system to buy, freedom to move between microcontroller families, almost instant circuit changes, cost savings on components (you only buy the bits you need). Simulation is built into Microchip's IDE, but its not visual and realy not intended for ... well now I come to think of it, anybody (IMO Microchip make good components and terrible PC software). BTW the new Java based ide, MPLABX is even worse. Personally I use Proteus, it can do mad things like breakpoint on a voltage level. Most simulators will also allow you to produce a PCB. Hope that helps George
    Gert,
    Yes, PICKIt2 works but I think they (Microchip) doesn't add any device files for it anymore so new(ish) PIC devices won't program or debug from within MPLAB. I do think the standalone application allows you tp program newer devices though. I don't use MPLAB myself so I haven't really kept up - and I've got a PICKit3 so....
    I really wish MELABS/Mecanique would add (if at all possible, I don't know) support for hardware level debugging to MicroCode Studio, or produce a detailed how-to-guide on how to set it up within MPLABX. I've never been able to figure it out..... Don't let that put you off though - it IS possible to do!
    Oct 2013
    So if i buy the PBP3 Silver I can go on from there?
    I saw that the Microcode Studio + wasn't that expensive so I probably go for that at the same time.
    Maybe im a bit spoiled with the Basic Stamp and being able seeing what goes on in a very simple way.
    Hi Gert,
    Yes, absolutely....
    But is there a specific chip you want to program that the silver edition supports? Note that the silver edition doesn't support 18F series or the newer 16F1xxx series. The student edition supports an even less number of microcontrollers but it DOES support a couple from each family (except the 10 series), which might be handy, and it's even cheaper. If I were you, and there isn't a specific chip you're targeting for which you NEED the silver edition, I'd consider the Student Edition as a start but also making sure it's possible to upgrade to Silver or Gold if/when the need arises.
    While looking around I saw that Mecanique (the authors of MCS) give you MicroCodeStudio PLUS for free when you buy PBP3 from them - worth considering!
    I'm not sure how in circuit debugging works on the Stamps these days, feel free to enlighten me though.
    What I can tell you is that I started playing with a BS1 ~20 years ago, quckly moved on to a BS2, then got PBC and later PBP after which I've never looked back. Once you get up to speed with PBP I honestly don't think you'll miss the Stamp. But you need to keep in mind that with the power and flexibility of PBP (but mostly all the devices it supports) comes a little bit of complexity compared to the Stamps. Lots of people here to help if/when needed though!
    Oct 2013
    Wink Re: Newbie migrating from Basic Stamp to PIC
    Ok, got the Silver and the IDE+.
    However, after some hours fiddling around and Googling I managed to get PBP3 to work with MPLABX IDE :-)
    Compiled and run a small test program on the Pickit2, and guess it worked.
    Could have save a few buck not getting the IDE+ and gone for the Gold instead.
    Time start reading some PIC datasheets and actually understand what im doing. This is going to be fun, be prepared for a lot of stupid questions.
    First project will be a snow depth meter (I hope).
  1. Moving from Basic Stamp and MIKROE basic to PicBasic PRO
    Last Post: - 6th March 2013, 06:27
  2. Yet another SERIN2 problem - Conversion from Basic Stamp
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 24th October 2012, 08:08
  3. PicBasic Pro to Basic Stamp conversion?
    By Kirk Fraser in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 07:49
  4. Basic Stamp BS2 replacement?
    By tenaja in forum Schematics
    Last Post: - 17th November 2009, 18:27
  5. serial comm from Pic to STAMP
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 5th April 2004, 00:58
