pic18f252 PWM duty update : Help
Results 1 to 10 of 10
    Default Re: pic18f252 PWM duty update : Help
    You are overwriting the two LSB's of the dutycycle because you have CCP1CON = %00001100 within the FOR/NEXT loop. So you're actually only updating the dutycycle once every four times thru the loop.
    Move the initialisation of the CCP module outside of the FOR/NEXT loop.
    DUTY VAR word
    TRISC.2 = 0
    PR2 = 200 ' Set PWM Period
    CCP1CON = %00001100 ' Select PWM Mode
    T2CON = %00000101 ' Timer2 = ON + 1:4 prescale ( about 10 KHz )
      FOR DUTY=260 TO 325
        ccp1con.bit4=duty.bit0
        ccp1con.bit5=duty.bit1
        CCPR1L = duty>>2
        debug dec duty, 13 ,10
        pause 1000 ' change duty every one sec.
      next duty
    Jun 2008
    Varese , Italy
    Thanks a lot Henrik for the great help.
    It is a very useful reply : it solved my problem.
    best regards,
    Ambrogio
    IW2FVO , North Italy.
    Jun 2008
    Varese , Italy
    I am having another issue with this PWM output.
    I understand from the data sheet that the duty cycle should have a 10 bit resolution since my PIC runs at 40 Mhz and the PWM freq is 10 Khz.
    The DC should then range from 0 to 1023 : I did try to sweep the DC in that way and I found that the output stays HI if the the DC is more then 800 ( plus or minus ): there is no more pulse : it is not a 10 bit ?!
    What am I doing wrong ?
    Any clarification for me ?
    regards,
    Ambrogio
    Post the code you're actually using for that test and someone will most likely see what's going on.
    Jun 2008
    Varese , Italy
    THIS IS THE CODE:
    TRISC.2 = 0 ' PORTC.2 IS OUTPUT
    FOR DUTY=1 TO 1023
    GOSUB READ_DATA ' READS ADC INPUT
    GOSUB SERIAL_OUT ' SEND DATA TO SERIAL PORT FOR DISPLAY
    CCPR1L = duty>>2
    NEXT DUTY
    THANKS
    AMBROGIO
    The reason is because you have PR2 set to 200.
    Remember how the PWM generator works: Basically, the PWM cycle starts over when TMR2 equals PR2 and because TMR2 is concatenated with two more bits at the "low end" the available number of discrete dutycycles is PR2*4 or, in this case, 800.
    Jun 2008
    Varese , Italy
    Henrik,
    thanks for the interest.
    I have read the data sheet again but it is still not clear to me: could you please spend few more words for me ?
    ( Will I have 10 bit resolution if PR2 is set to 256 since 256*4 =1023 : is this assumption correct ? ).
    Thanks for your time
    bst rgds,
    Ambrogio
  1. 3 channel PWM with customize duty cycle
    By photoelectric in forum mel PIC BASIC Pro
    Last Post: - 16th May 2011, 13:49
  2. Replies: 9
    Last Post: - 8th October 2008, 11:15
  3. PWM PIN(S), DUTY, CYCLE ?Plural possible?
    Last Post: - 17th November 2007, 20:41
  4. Help with PWM and duty and integers
    By JDM160 in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 06:03
  5. PWM _ Duty Cycle in Tenths
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 17th May 2004, 12:09
