Can't make RA1 a digital Input on (10 out of 20) 16F887.
Results 1 to 17 of 17
    Aug 2003
    Default Re: Can't make RA1 a digital Input on (10 out of 20) 16F887.
    %000000010
    %00000010
    They are both the same number.
    Google RA1 Digital, and you can see the pain!
    if portA are all digital inputs, what value do you get reading portA into a byte?
    byte = PORTA;
    What happens if you do this:
    HIGH PORTA.0
    PAUSE 250
    LOW PORTA.0
    PAUSE 250
    So that portA isn't powering an LED while A1 is being read?
    This is your code tweaked for a PIC16F690, and it works:
        __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
    ;__config _CONFIG2, _WRT_OFF & _BOR40V
    DEFINE OSC 20
    ANSEL = 0
    ANSELH = 0
    ADCON0 = 0
    ADCON1 = 0
    CM1CON0 = 0
    CM2CON0 = 0
    CM2CON1 = 0
    CCP1CON = 0
    ;CCP2CON = 0
    portb=0
    portc=0
    porta=0
    TRISA = %00000010
    TRISB = 0
    TRISC = 0
    ;TRISD = 0
    ;TRISE = 0
    Startup:
    LOW PORTA.0
    PAUSE 250
    HIGH PORTA.0
    PAUSE 250
    IF PORTA.1 = 0 THEN
    LOW PORTc.1
    HIGH PORTc.1
    GOTO Startup
    The registers a 690 does not have have been commented out. You will need a pull up on your input pin.
    Sorry I don't have an 887 to test upon.
  1. 16f887 portc input problems
    By lockjawz in forum mel PIC BASIC Pro
    Last Post: - 31st March 2011, 15:02
  2. Replies: 2
    Last Post: - 1st May 2009, 09:23
  3. Really slow digital input
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 05:06
  4. 18F4550 digital input
    Last Post: - 29th March 2007, 03:43
  5. Replies: 2
    Last Post: - 5th June 2005, 20:55
