Can't make RA1 a digital Input on (10 out of 20) 16F887.
Results 1 to 17 of 17
    Sep 2013
    Default Can't make RA1 a digital Input on (10 out of 20) 16F887.
    I thought I had my large code finalized, and now half of my boards have a problem.
    The RA1 input always reads 0. I have ANSEL = 0, ANSELH = 0, and have various settings of the other registers from the datasheet.
    I also tried using the alldigital.pbp include file.
    Below is a simplified test program (with the same problem) that flashes one of my existing LED's(RA0) and another LED(RE1) is controlled with a toggle switch input. I have a 10K pull up resistor on the switch input (RA1) to 5V, and I have measured the voltage on the chip pin. It changes state correctly with the switch, but the LED(RE1) stays on.
    If I use any port other then RA1, it works on all the PIC's.
    Also, all of the chips are running the code...cause the first LED flashes as it is supposed to.
    I feel that I am not getting something disabled correctly with the AD conv or the Comparators.
    This is my first time posting. I have spent hours with the datasheet. I usually find my answers by just reading others...but?
    Paul
    __config _CONFIG1, _HS_OSC & _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF
    __config _CONFIG2, _WRT_OFF & _BOR40V
    DEFINE OSC 20
    ANSEL = 0
    ANSELH = 0
    ADCON0 = 0
    ADCON1 = 0
    CM1CON0 = 0
    CM2CON0 = 0
    CM2CON1 = 0
    CCP1CON = 0
    CCP2CON = 0
    TRISA = %000000010
    TRISB = 0
    TRISC = 0
    TRISD = 0
    TRISE = 0
    Startup:
    LOW PORTA.0
    PAUSE 250
    HIGH PORTA.0
    PAUSE 250
    IF PORTA.1 = 0 THEN
    LOW PORTE.1
    HIGH PORTE.1
    GOTO Startup
    Default Re: Can't make RA1 a digital Input on (10 out of 20) 16F887.
    Try this wild guess:
    IF PORTA.1 = 0 THEN
    PORTE.1 = 0
    PORTE.1 = 1
    EDIT: I also went through the datasheet and can't see any register you could have forgotten.
    Sep 2013
    Thanks for the reply.
    I gave that a try and still have the same results. I was originally using variable names for each pin, but removed them to simplify.
    I have done a lot of programming without problem. Can't believe I can't make an input work.
    In my larger program, I actually save this pin state to a USB flash drive. The input is always 0.
    The ANSEL = 0 and ANSELH = 0, is working for all the other pins they deals with.
    Paul
    Found it:
    TRISA = %000000010
    I count 9 digits.
    Sep 2013
    Wow...
    I really thought that was gonna be it. Didn't notice that extra bit.
    But, it didn't seem to make them work...the other 10 all seem to be consistently working.
    Kinda wish I would have put the micro in a socket.
    What about VRCON? Is this a Read, Modify, Write issue?
    Paul
    I don't know the details of RMW. Hopefully someone else will have an idea 'cause this was all I had.
    So, it's not only the PIC that differs on the ones that doesn't work, you are changing the whole board, including the PIC, correct?
    I think that since it works on some PICs (or boards rather, if that's the case) the code is likely not the fault. Had it been a faulty register setting it wouldn't have worked on any of them - but I've been wrong before....
    What's the supply voltage of the PIC (5V?) and what voltage levels are present at RA1 with the switch in either location?
    You say that you ground the pin to "make" the signal, is it possible that there are TWO (or more) grounds in your system and that they aren't connected. When you measure the voltage you reference the "correct" ground which, for whatever reason, isn't connected to PICs ground so it doesn't see the voltage that your DVM does?
    I'm pretty sure it's not RMW, especially so since your two outputs are on different ports. A Read Modify Write issue usually presents itself when you're trying to do several consecutive bit operations on a single port.
    I'm leaning towards a hardware issue of some sort though it IS strange that it works with "any other pin except RA1".... doesn't make sense but things usually doesn't untill you find the real reason.
    The PIC's are "soldered in" on all the boards you have?
    All the boards are from the same batch?
    All the PIC's are from the same batch and silicon rev.?
    George
    Quote Originally Posted by paulgrut View Post
    So in summary, You have 20 pics all programmed alike, and only half work as expected?
    Perhaps you have gotten some sour hardware . . . perhaps?
    Can you toggle those pins with a simple code, apart from this program?
    Sep 2013
    Yes. I have 20 boards with the PIC soldered in. And on half the RA1 input does not work.
    I am able to make the RA1 act as an output and it works correctly on all of them.
    I am seeing 2 different silicon date codes on the chips, but the problem is with some of each.
    The circuit boards are all from the same batch.
    The RA1 input is held high with 10K pullup resistor to 5V. The switch pulls this to ground. I have verified the voltage on the chip pin
    and it changes from 5V to 0V with the switch. I am going to look over all the ground traces and make sure there isn't (as Henrik asked)
    a seperated ground. Although the boards all look to be in good shape.
    Thanks for any other ideas. I might order some new 887's and see what happens. And some sockets also...
    Paul
    I realize it's a pain to unsolder two PICs but the obvious thing to try is swapping the PIC from a working board to with the PIC from a non working board. Cold comfort but at least you will have a better idea if its the board or the PIC. Are the PICs DIP or SMD? If they're SMD try ChipQuik. BTW there is an errata for the 887, didn't see anthing obvious. George
    Sep 2013
    Update.
    All of the Ground traces are correct and tied together.
    But....After checking again. RA1 WILL NOT work as an output either.
    I will swap 2 of the chips. I agree, it is the next step. Not too bad...they are DIP.
    Paul
    Sep 2013
    Swapped the pic on a working board and a not working board....
    Problem stayed with the pic. Must be a pic problem.
    Just can't help but think I have something configured wrong in the code.
    What could cause a pic failure? These boards were built then tested bad. (no extended use) .
    Paul
    have you verified the code in the working and non working PIC's?
    Paul
    Static Electricity, short circuit, overload, bad programmer (device). What was the source of those PICs ? Microchip, Mouser, FleaBay ? Lots of Fake Chips out there, maybe you got unlucky that way . . . you gotta ask yourself, "What do electronics manufacturers do with parts that do not meet their high standards?". I would bet they wholesale them to somewhere in unmarked condition as scrap and they mysteriously get marked and marketed as "genuine". I am very dubious about off list suppliers.
  1. 16f887 portc input problems
    By lockjawz in forum mel PIC BASIC Pro
    Last Post: - 31st March 2011, 14:02
  2. Replies: 2
    Last Post: - 1st May 2009, 08:23
  3. Really slow digital input
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 04:06
  4. 18F4550 digital input
    Last Post: - 29th March 2007, 02:43
  5. Replies: 2
    Last Post: - 5th June 2005, 19:55
