Beginner in PicBasic. I really need some help understanding this program.
Results 1 to 9 of 9
    Sep 2013
    Default Beginner in PicBasic. I really need some help understanding this program.
    So me and my friends want to learn how to start using the PicBasic codes for creating a program. What are the functions of each code in the said program:
    Device 16F877A Declare Xtal = 4
    ADCON1 = 7
    PortB_Pullups = On
    All_Digital = TRUE
    TRISA=%000000
    TRISB=%00001111
    TRISC=%00000000
    TRISD=%00000000
    TRISE=%000
    Dim Time As Byte
    Dim PUJ As Byte
    Dim BUS As Byte
    Dim TAXI As Byte
    Dim display As Byte
    Dim display2 As Byte
    Dim display3 As Byte
    Clear PUJ
    Clear BUS
    Clear TAXI
    Clear Time
    Clear PORTA
    Clear PORTB
    Clear PORTC
    Clear PORTD
    Clear PORTE
    DelayMS 500
    Rst:
    PUJ= Dig PUJ,0
    TAXI = Dig TAXI,0
    BUS = Dig BUS,0
    display = PUJ
    display2 =BUS
    display3 =TAXI
    PORTC = display
    PORTD = display2
    PORTA = display3
    Counting:
    For Time = 1 To 400
    If PORTB.0 = 0 Then
    DelayMS 50
    While PORTB.0 = 0:Wend
    Time = 1
    PUJ = PUJ + 1
    If PUJ > 9 Then
    PUJ = 0
    EndIf
    PUJ = Dig PUJ,0
    display = PUJ
    PORTC = display
    EndIf
    If PORTB.1 = 0 Then
    DelayMS 50
    While PORTB.1 = 0:Wend
    Time = 1
    BUS = BUS + 1
    If BUS > 9 Then
    BUS = 0
    EndIf
    BUS = Dig BUS,0
    display2 = BUS
    PORTD = display2
    PORTA = display3
    EndIf
    If PORTB.2 = 0 Then
    DelayMS 50
    While PORTB.2 = 0:Wend
    Time = 1
    TAXI = TAXI + 1
    If TAXI > 9 Then
    TAXI = 0
    EndIf
    TAXI = Dig TAXI,0
    display3 = TAXI
    PORTA = display3
    EndIf
    DelayMS 150
    Next Time
    Clear PUJ
    Clear BUS
    Clear TAXI
    Clear Time
    PUJ= Dig PUJ,0
    TAXI = Dig TAXI,0
    BUS = Dig BUS,0
    display = PUJ
    display2 =BUS
    display3 =TAXI
    PORTC = display
    PORTD = display2
    PORTA = display3
    GoTo Counting
    We all know that: Device 16F877A is the microcontroller we used then
    Declare Xtal = 4 is the value of the oscillator in Megahertz. So far we only know the first two lines...
    Default Re: Beginner in PicBasic. I really need some help understanding this program.
    Hello,
    There are several manufacturers of BASIC compilers for PIC. (There's Swordfish, Proton, MikroE, Melabs and so on).
    I don't know for which one YOUR program is but as far as I can see it's not for any of the compilers being discussed on this forum, which is PBP (and to some degree the old PBC) from MicroEngineeringLabs.
    Your best bet is to find a forum where the particular compiler you and your friend is trying to learn is being discussed. If that compiler IS PBP from Melabs then you ARE at the right place but the code you posted is not compatible.
    Miami, Florida USA
    Yes, that code is definitely not PBP. Although, it can be easily modified to work in PBP.
    Anonymous
    Looks to be PROTON basic ...
    sooo, ... hitting the HELP/Documents menu key should give you all info you need ...
    that's also called " RTFM " or Read That Friendly Manual !!! ...
    FWORD EDIT :Archangel
    PS: licensed product ??? ... hmmmm ...
    Sep 2010
    Las Vegas, NV
    Friendly. I thought that F meant something else.
    This forum went very prim ... for a moment
    that's why I bailed out from my moderator job ...
    Quote Originally Posted by Acetronics2 View Post
    Just trying to CYA Al
    JS
    Hi,Joe
    That episode learnt me one precious "lifejacket" :
    there's one thing that is totally impossible to moderate: Human stupidity ...
    Best regards
  1. [Beginner Tutorial] How to get started with PICBASIC PRO Demo, MPLAB & PICKIT 2
    By mister_e in forum FAQ - Frequently Asked Questions
    Last Post: - 18th October 2014, 23:47
  2. DIV32 Understanding
    By enauman in forum mel PIC BASIC Pro
    Last Post: - 19th January 2013, 21:44
  3. PIC12f629 beginner program
    By kiwi newbie in forum General
    Last Post: - 20th October 2010, 08:18
  4. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
