SPI woes
Results 1 to 6 of 6
Thread: SPI woes
    Sep 2005
    Campbell, CA
    Default Re: SPI woes
    I'm using a PIC 18F8723 and Pin H.2 for SDI. It is tristated, and the external memory function is turned OFF.
    Charles Linquist
    Hi Charles,
    I can't help thinking it's a hardware issue.
    Can you read the state of pin "manually" and get the correct state, perhaps the input is damaged?
    Are you probing directly on the pin on the PIC, perhaps there's a bad solder joint or PCB track?
    USA - Arizona
    Maybe I read the manual wrong, but in Mode5 yhr data is clocked on the falling edge (right before the falling edge); which could potentially give you a 0x10 reading (based on your picture). I don't think that directly answers your question, but you may as well make sure you are using the right mode (and the analyzer picture matches that mode).
    Sep 2005
    Campbell, CA
    I found part of the problem: The accelerometer is running at 2.5 V, the PIC is running at 5. I was using a Tiny Logic buffer to do the level shifting. The buffer was a Schmitt trigger type with a 2.2V threshold. The accelerometer output didn't always reach that level and the output didn't toggle reliably. I'm getting data through the buffer now (I raised the accelerometer Vcc to 3V by choosing a different LDO regulator for it). But the data still isn't right. Languer is probably right, and I'll try changing the mode.
    I don't know why the PBP manual can't use normal datasheet terms, such as "the data is sampled on the clock rising edge" or something like that instead of the way they describe it!
    Charles Linquist
  1. Capture woes...
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2011, 09:36
  2. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  3. ICD Woes
    By spad13m in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 06:56
  4. Still HSEROUT woes
    Last Post: - 11th July 2006, 22:13
  5. SPI on a pic without hardware SPI?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 26th April 2006, 14:29
