PAUSEUS Using a 16MHz Oscillator
Results 1 to 7 of 7
    Miami, Florida USA
    Default PAUSEUS Using a 16MHz Oscillator
    I am sure this question or a similar one has been posted before, but I can't find it. I'm using a 16 MHz internal oscillator and according to the 2.60 PBP manual the minimum pause I can get is 5us. Now, to obtain a shorter delay the manual recommends using ASM....ENDASM. Can somebody enlight me on how to do this?
    Thank you,
    Anonymous
    Default Re: PAUSEUS Using a 16MHz Oscillator
    At 16MHz one instruction cycle is 250ns. To get 1us delay you could do
       NOP
       NOP
       NOP
       NOP
    Any longer and you'd probably set up a loop or use some other tricks.
    Miami, Florida USA
    Nice!
    Can I use this ASM code inside a IF....ENDIF condition? For example,
    IF something
    NOP
    NOP
    NOP
    NOP
    Anonymous
    Yes, of course you can.
    Miami, Florida USA
    Thanks. I'll try that.
    Anonymous
    just think the IF ... ENDIF will take some time ... ( especially if "something" is a complex expression ) ...
    Jan 2007
    This might be a great opportunity to utilize an O-scope :-]
    Have fun!
  1. Pauseus Doubt
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 1st February 2012, 18:14
  2. LCD works at 4MHz, but not 12 or 16MHz
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 01:23
  3. Pauseus
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 26th April 2008, 10:07
  4. PAUSEUS command
    By AndrewC in forum General
    Last Post: - 10th February 2006, 03:00
  5. Can anyone help at getting OWIn & OWOut to work @ 16MHz?
    Last Post: - 24th January 2006, 11:08
