EEPROM or DATA issue with 16F1503
Results 1 to 3 of 3
    Aug 2011
    Default EEPROM or DATA issue with 16F1503
    I have written some code that I want to load into an EEPROM aboard a 16F1503. I used in the past the command EEPROM 1,[1] , well on a 16f628 or 873A using PBP 2.47. It works. On the 1503 that is new to me and a recent upgrade to PBP 3.0.X I switched to the DATA statement.Such as DATA @1, 1.
    When I compile, it errors out and says: undefined symbol (EEPROM_START). Not sure why. I tried the examples in the manual with the same result. I have also tried. data@1, 1 data @ 1, 1 data@ 1,[1] ect. different ways of typing it out. No joy. It looks like the 1503 does has eeprom registers so, not sure what the error is telling me.
    After some search online looks like I might need to modify the INC file for the 16F1503. Not exactly sure about this or what to add to it.
    Thanks.
    Aug 2011
    Default Re: EEPROM or DATA issue with 16F1503
    Well after going through data sheet again comparing to other chips I have, looks like the 1503 DOES NOT have on board EEPROM. So it is no wonder I was not getting the results!
    Aug 2003
    Quote Originally Posted by scasale View Post
    And why EEPROM_START is not defined in the include for the particular device,
    otherwise it would only likely be a matter of editing it.
  1. Issue using DATA statement with 16F1933 in PBP2.60
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 10th August 2010, 01:36
  2. EEPROM vs DATA
    By 90alper90 in forum mel PIC BASIC Pro
    Last Post: - 14th July 2009, 20:51
  3. DATA and EEPROM Commands
    By websmith in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2006, 08:40
  4. Storing Data Issue
    Last Post: - 10th June 2005, 13:40
  5. HOw do I keep my EEprom Data
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 5th April 2005, 17:58
