I don't think it'll recognise PLLEN directly so in order to enable the PLL (when using the internal oscillator) you'd do OSCTUNE.6 = 1 (set bit 6 of OSCTUNE).
The compiler recognises all the names of all the registers but not the names of each individual bit in the registers. You can, however create an alias and use it:Your OSCCON = %11100010 would result in 4MHz on the internal oscillator (it's controlled by bits 4 thru 6, which I've highlighted in red, in that register). Set those three bits to 111 to get 8MHz from the oscillator (resulting in 32MHz once the PLL is enabled).Code:PLLEN VAR OSCTUNE.6 ' Of course you could give it any name you like. PLLEN = 1
At 32MHz system clock and PR2=63 (not 16) you'll get 125kHz and 8 full bits (256 "steps"). But you need to "split" those 8bits so that the two lowest significant bits of your dutycycle value ends up in CCPxCON bits 4 and 5 (if you're using the second PWM module) and the upper 6 bits ends up the lower 8 bits of CCPRxL.
So, the actual value to get 50% would be 127 or 128 but, using the CCP2 module, you do something like/Henrik.Code:Duty = 127 CCP2CON.4 = Duty.0 CCP2CON.5 = Duty.1 CCPR2L = (Duty >> 2)
