MicroSD - SD card FAT32 newbie
Results 1 to 4 of 4
    Apr 2012
    Ptolemaida
    Default Re: MicroSD - SD card FAT32 newbie
    Hello mackrackit,
    i found that there is a problem with FSinit subroutine, pic's programm stuck in waitforcmdtimeout loop of SDFSHC32d file without returning to main programm. I tried a fix that a user(Alexey) did and worked out!!
    loopcount var byte
    loopcount= 0
    waitforcmdtimeout:
    if loopcount = 255 then
    SD_CS = 1
    loopcount = loopcount +1 'ExtraCode
    But i got responce :
    FAT_error= 6 SDC_status= 1 SDC_response= 255
    FAT_error= 7 SDC_status= 1 SDC_response= 255
    Also i forgot to say that i run the program at 32Mhz but still same results. Q: Is there need of 40Mhz ++ speeds ?? Isn't 32Mhz enough ?
    I think MeLabs has code only for FAT16 and not for FAT32 example. Anyhow i'll use your advise and try to use one FAT16 example when i get my hands on 1 2Gb or less microSD
    Apr 2012
    Ptolemaida
    As it seems it's a pitty... But picbasic can't handle SD/microSD FAT32 formated cards yet... I hope someone in the future will add Statements, include files etc etc for this work.
    One man's magic is ANOTHER man's engineering.
    Supernatural is a null word
  1. SDHC (FAT32 for SD cards)
    By mackrackit in forum Code Examples
    Last Post: - 15th October 2023, 20:16
  2. FAT32 SD cards use with sdfshc32d.pbp
    By Alexey in forum PBP Extensions
    Last Post: - 10th March 2015, 16:17
  3. MicroSD Cards and SDFS
    By rsocor01 in forum General
    Last Post: - 28th August 2010, 06:53
  4. yes card
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 18:25
  5. SD-Card
    By glaubertadeu in forum General
    Last Post: - 27th April 2005, 15:57
