Toggle program branch ussing interrupot by button?
Results 1 to 14 of 14
    Default Toggle program branch ussing interrupot by button?
    The idea is as follows.
    When launched, the LOOP1 in program is working and doing something. If user presses the button, interrupt is generated and LOOP2 engaged. When button pressed again, LOOP2 terminates and LOOP1 starts.
    Any example code?
    Default Re: Toggle program branch ussing interrupot by button?
    Have a flag (bit variable) which you toggle in the ISR.
    In the main program you poll the flag and decide which subroutine (loop) to execute.
    This will have the potential drawback of always finishing the current subroutine (loop) before switching, is that a problem?
    with PBP "on interrupt" it looks this figure is covered in the manual @ $ 5.66 ( RESUME xxx ) : you can choose the "return" adress xxx as you want ... so LOOP2 always completes.
    - also note if you do not clear the interrupt flag ( With a DEFINE ) you automatically re-enter the ISR when completed !
    - For DT interrupts ... I didn't check if the resume address can be freely chosen ...
    - last idea is simply to overwrite the interrupt return address on the stack ... ( with asm "push" and "pop" macros see midrange manual, interrupts chapter ), depending on the button state.
    I don't want to include the button status check routine in the loops, since whole program works with microsecond delays and high accuracy. This is why I wanted to use interrupt. LOOP1 and LOOP2 are totally independent tasks, they don't use same variables, timings or whatsoever.
    Nov 2007
    West Covina, CA
    That's a good question...
    I wonder if something like this would work?
    x VAR BIT
    ;----------------------- Setup Interrupts --------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Darrel Taylor's Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ; Include if using PBP interrupts
    INT_LIST  macro ; IntSource,          Label,  Type, ResetFlag?
        INT_Handler    INT0_INT,     Button_ISR,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    ;----------------------[Initialise Interrupts]-----------------------
    @   INT_ENABLE  INT0_INT         ; Enable Button interrupt input
    x = 0       ' Clear button status flag bit
    PAUSE 100
    GOTO loop1  ' Start at loop1 routine
    ' ---------------- Independent program routines -------------------------
    loop1_start:
    @ INT_RETURN    ; Reset the ISR
    loop1:
        ' Perform one type of "time critical" function
    GOTO loop1
    loop2_start:
    loop2:
        ' Perform a different type of "time critical" function
    GOTO loop2
    ;--------------------[Program routine selector ISR]----------------------
    ; make sure button signal debounced
    Button_ISR:
        x = !x      ' Toggle x status flag bit
        IF !x THEN
            GOTO loop1_start    ' Go here when x=0
            GOTO loop2-start    ' Go here when x=1
    @ INT_RETURN
    Like Henrick said, the routines could be cut short anytime the button is pushed though.
    Louie
    Thanks. As I can see, the code is for PIC18xxx family. Will it work on 12xx or 16xx ?
  1. TOGGLE will not go LOW
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 10th August 2014, 16:53
  2. toggle switches and buttons-- need little help
    By electromark in forum General
    Last Post: - 25th October 2012, 22:35
  3. Toggle command
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 16th December 2011, 02:07
  4. toggle or count?
    Last Post: - 26th May 2008, 08:54
  5. BRANCH/BRANCHL for GOSUB
    By selbstdual in forum PBP Wish List
    Last Post: - 20th February 2007, 14:29
