is there a simple way make a condition true on a rising edge on an input
Results 1 to 3 of 3
    EDWARD's Avatar
    EDWARD Guest
    Default is there a simple way make a condition true on a rising edge on an input
    is there a way to make a if then statement like this:
    IF rising edge is detected on portb.0 THEN
    do some code
    im trying to increment a varible by 1 every time it receves a low high transistion on input pin portb.0. the timing between of the signals could be from 10 to 500 ms. i cant have any long pauses.
    Post
    Since you want to use PortB.0 you can check the interruptflag.
    OPTION_REG.6 = 1       ' rising edge
    INTCON.1 = 0           ' reset the interruptflag
    IF INTCON.1 = 1 THEN
       ' your code
    EDWARD's Avatar
    EDWARD Guest
    Default that works.
    well thats exctly what i needed. thank you very much.
    i was trying to run a chunk of code only when portb.0, on my 16f73 configured and set as an input, read a rising edge signal. as ingvar has shown i can use interrupts.
    'this part is only run once at the top of my program'
    'this part is contained in a loop'
    ' your code
  1. mS Timer
    By whmeade10 in forum mel PIC BASIC Pro
    Last Post: - 8th September 2020, 12:12
  2. Need help - Just want to make a simple switch using RF Modules
    Last Post: - 25th October 2009, 10:38
  3. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 16:10
  4. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  5. Best way to find a rising edge?
    By jcsquire in forum mel PIC BASIC Pro
    Last Post: - 31st May 2006, 15:11
