Not sure it's the only problem but the first thing I see is:
/Henrik.Code:DEFINE LCD_DREG PORTC DEFINE LCD_DBIT 2 ' <----This can only be 0 or 4 - you can't "start" on an aribtrary pin - ONLY 0 or 4.
in others language is possible?
Sure, I can write it in Swedish if you want:
Jag är inte säker på att det här är det enda problemet men det första jag ser är:Code:DEFINE LCD_DREG PORTC DEFINE LCD_DBIT 2 ' <----Det här kan bara vara 0 eller 4 - det går inte att "börja" på valfri pinne - ENDAST 0 eller 4.
Have you looked at DT's LCD_any_pin solution still using Picbasic pro. IF the question is if it is possible in other compilers then I think it might be possible..
Or you write your own LCD function and then you can use any pin for this.
Too bad the forum dont allow for chinese characters .. or we could add some more languages as well
Swedish? Anyone can do Swedish. Can you write it in Klingon? Now that would be a feat!
Sure, I can write it in Klingon, here you go:
Obviously I have NO idea if that's correct though, I speak Klingon like I speak C - not at all... :-)bIpIv'a',
wej qarbej qay' neH 'ach wa'DIch 'oH vIlegh:
Code:DEFINE LCD_DREG PORTC DEFINE LCD_DBIT 2 '<---laH neH 'oH 0 4 pagh-pagh "start SoH" aribtrary 'emDaq-neH 0 4 pagh.
Here's the translator I used.
Anyway, I think we've had enough fun for now. Darrels Routine will most likely be the answer if the OP wants to stick with PBP.
sorry by my message, I wanted to say something else, programming language.
yes, the problem is DEFINE DBIT 2, I change pins and all correct in ISIS.
but I need pin C2-5 for data 4 bits of LCD
I tested this code
http://www.picbasic.co.uk/forum/showthread.php?t=7038
and I work with pin C2-5 for LCD data
RS in pin C0 and E in pin C1
all correct, ISIS work with my code and LCD_AnyPin.pbp solution.
But I tested my code in real PIC and not work, I modified configurations bits in MPLAB and nothing.
I think that must be some PIC configuration byte that is not properly configured, any help?
I all have this:
TRISA = %00111111 <-- all A pins are input
TRISC = %00000000 <-- only used for LCD 16x2
ANSEL = %00000011 <-- I need bit 0 and 1 for A/D
WPUA = 0
IOCA = 0
