Pic16f616 with lcd 16x2 problem
Results 1 to 8 of 8
    Nov 2012
    Unhappy Pic16f616 with lcd 16x2 problem
    Hello, I have LCD connected to PIC16F616
    This is code LCD configuration
    Include "MODEDEFS.BAS"
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 2
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    RW pin in LCD to GND
    and
    TRISA = %00111111
    TRISC = %00000000
    ANSEL = %00000011
    I write in LCD and not working, wrong characters in LCD and ISIS simulation no working with my simple hello world code..
    idea?
    Default Re: Pic16f616 with lcd 16x2 problem
    Not sure it's the only problem but the first thing I see is:
    DEFINE LCD_DBIT 2   ' <----This can only be 0 or 4 - you can't "start" on an aribtrary pin - ONLY 0 or 4.
    Nov 2012
    in others language is possible?
    Sure, I can write it in Swedish if you want:
    Jag är inte säker på att det här är det enda problemet men det första jag ser är:
    DEFINE LCD_DBIT 2   ' <----Det här kan bara vara 0 eller 4 - det går inte att "börja" på valfri pinne - ENDAST 0 eller 4.
    Mar 2006
    China
    Have you looked at DT's LCD_any_pin solution still using Picbasic pro. IF the question is if it is possible in other compilers then I think it might be possible..
    Or you write your own LCD function and then you can use any pin for this.
    Too bad the forum dont allow for chinese characters .. or we could add some more languages as well
    Sep 2010
    Las Vegas, NV
    Swedish? Anyone can do Swedish. Can you write it in Klingon? Now that would be a feat!
    Sure, I can write it in Klingon, here you go:
    bIpIv'a',
    wej qarbej qay' neH 'ach wa'DIch 'oH vIlegh:
    DEFINE LCD_DBIT 2   '<---laH neH 'oH 0 4 pagh-pagh "start SoH" aribtrary 'emDaq-neH 0 4 pagh.
    Obviously I have NO idea if that's correct though, I speak Klingon like I speak C - not at all... :-)
    Here's the translator I used.
    Anyway, I think we've had enough fun for now. Darrels Routine will most likely be the answer if the OP wants to stick with PBP.
    Nov 2012
    sorry by my message, I wanted to say something else, programming language.
    yes, the problem is DEFINE DBIT 2, I change pins and all correct in ISIS.
    but I need pin C2-5 for data 4 bits of LCD
    I tested this code
    http://www.picbasic.co.uk/forum/showthread.php?t=7038
    and I work with pin C2-5 for LCD data
    RS in pin C0 and E in pin C1
    all correct, ISIS work with my code and LCD_AnyPin.pbp solution.
    But I tested my code in real PIC and not work, I modified configurations bits in MPLAB and nothing.
    I think that must be some PIC configuration byte that is not properly configured, any help?
    I all have this:
    TRISA = %00111111 <-- all A pins are input
    TRISC = %00000000 <-- only used for LCD 16x2
    ANSEL = %00000011 <-- I need bit 0 and 1 for A/D
    WPUA = 0
    IOCA = 0
  1. Interfacing 16x2 LCD to PIC18F2520
    By spotlite in forum mel PIC BASIC Pro
    Last Post: - 21st January 2012, 08:29
  2. swap lcd 16x2 with 20x2
    By kzeoprf in forum General
    Last Post: - 2nd September 2011, 16:25
  3. PIC16F616 HWPM Problem
    Last Post: - 4th April 2009, 09:20
  4. Problem with servo and PIC16F616
    By Forkosh in forum mel PIC BASIC Pro
    Last Post: - 18th November 2007, 21:22
  5. PIC16F616 Comparator problem
    By JimA in forum General
    Last Post: - 15th October 2007, 14:56
