HWPM higher resolution stepping
Results 1 to 3 of 3
    Default Re: HWPM higher resolution stepping
    No, the HPWM command is limited to 8bit resolution. Years ago Darrel wrote a routine called HPWM10 or something like that which could be used instead of the normal HPWM to get 10bit resolution and provide glitchfree operation (IIRC) search the forum and you should be able to find it.
    With that said it's pretty straight forward to set the registers for the CCP manually. Plenty of examples on that as well floating around.
    Oct 2009
    Cheers Henrik, I'll have a search and see if I can find Darrels routine
  1. Synchronising HWPM to an external source
    By galliumman in forum General
    Last Post: - 6th December 2009, 18:03
  2. PIC16F616 HWPM Problem
    Last Post: - 4th April 2009, 09:20
  3. Zero crossing output with HWPM
    By bradhartmann in forum mel PIC BASIC Pro
    Last Post: - 6th December 2007, 19:17
  4. can HWPM use in PIC16f84a?
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 17:38
  5. Stepping motor Driver
    By mesamune80 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2006, 04:36
