16F886 and Voltage reference
Results 1 to 4 of 4
    Default Re: 16F886 and Voltage reference
    Hi, Peter
    may we understand your board design is already done and can't be altered ?
    If so ... see Hendrik's answer.
    another solution could be, if your board current draw is quite constant, to add a little calibration routine in your program : @ first power up, you use a known reference voltage on one ADC pin ... then the routine calculates a correction coeff to use in your ADC measurements ...
    say, IF the EEPROM cal value is $FF or $ FFFF ( generally is with newly programmed components ) , THEN you enter the cal. routine @ power-up ...
    The system has quite a high precision 5v regulator so I think I will stick with the VSS/VDD references for now but thanks for the ideas.
    Peter
  1. Fixed Voltage Reference
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2012, 12:27
  2. ADC with reference voltage
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 20th May 2010, 22:01
  3. ADC - 2 channels but not same voltage reference - how to?
    Last Post: - 25th November 2007, 20:03
  4. COMPARATOR - Voltage Reference settings
    Last Post: - 9th October 2007, 08:06
  5. AD Negative Voltage reference
    Last Post: - 28th June 2007, 16:01
