16F886 and Voltage reference
Results 1 to 4 of 4
    Default 16F886 and Voltage reference
    I have a project using all 11 ADC Channels on the 16F886.
    I note the external voltage reference channels/pins are shared with the ADC channels AN2 & AN3 :?
    Anyway round this? I can't disconnect the device the adc is measuring from the adc pins AN2,AN3.
    I'm fairly happy with the VDD/VSS reference method but was just thinking about using something with more precision than the power supply.
    Default Re: 16F886 and Voltage reference
    No way around it that I can think of.
    How much current does the system draw? Perhaps you can power the PIC from a (possibly buffered) voltage reference chip thus making Vdd more stable/accurate.
    Or use an external analog swich to connect either a voltage reference or your normal analog signal to one of the inputs, sample the voltage reference and use its value to apply correction in software.
    Hi, Peter
    may we understand your board design is already done and can't be altered ?
    If so ... see Hendrik's answer.
    another solution could be, if your board current draw is quite constant, to add a little calibration routine in your program : @ first power up, you use a known reference voltage on one ADC pin ... then the routine calculates a correction coeff to use in your ADC measurements ...
    say, IF the EEPROM cal value is $FF or $ FFFF ( generally is with newly programmed components ) , THEN you enter the cal. routine @ power-up ...
    The system has quite a high precision 5v regulator so I think I will stick with the VSS/VDD references for now but thanks for the ideas.
    Peter
  1. Fixed Voltage Reference
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 20th April 2012, 11:27
  2. ADC with reference voltage
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 20th May 2010, 21:01
  3. ADC - 2 channels but not same voltage reference - how to?
    Last Post: - 25th November 2007, 19:03
  4. COMPARATOR - Voltage Reference settings
    Last Post: - 9th October 2007, 07:06
  5. AD Negative Voltage reference
    Last Post: - 28th June 2007, 15:01
