Toggle program branch ussing interrupot by button?
Results 1 to 14 of 14
    Default Re: Toggle program branch ussing interrupot by button?
    Thanks. As I can see, the code is for PIC18xxx family. Will it work on 12xx or 16xx ?
    Nov 2007
    West Covina, CA
    Not for PIC12's or 16's.
    You'll have to download DT's Interrupts for them here and replace entry with:
    INCLUDE "DT_INTS-14.bas"    ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"    ; Include if using PBP interrupts
    I was kinda hoping someone would point out my errors in my suggestion, if any, before you went too far into a possible dead end.
    If you haven't tried DT's INTS, you're missing out on some awesome timing control when it comes to sequence of events. It took me a little while to understand but finally got some handle on it when I monitored two interrupts taking turns to run their routines, especially when one occurs while the other ISR is taking care of business.
    Louie
    Ok Louie, I'll take a stab at that if you wish... :-)
    If the program is looping around in Loop2 (x=1) when the interrupt occurs the ISR will toggle x to 0 and then GOTO Loop1_Start.
    At Loop1_Start there's an @INT_RETURN which will send it back into Loop2 since that's where it was when the interrupt occured.
    Nov 2007
    West Covina, CA
    Thanks Henrik, I stand corrected.
    CuriousOne, I tried to do something like this in the past and thought I came up with a better idea all of a sudden, but to avail.
    Louie
    I found a sample code here:
    http://darreltaylor.com/DT_INTS-14/hello.html
    The code is OK for me, since I also need a selected loop indication via led. What if I mod it a like this:
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    IF LED1=1 then goto LOOP1 ELSE GOTO LOOP2
    LOOP1:
    LOOP2:
    @ INT_RETURN
    Nov 2007
    West Covina, CA
    Sorry for the delay, but I don’t think that would be a good solution since the ISR should only spend enough time in there to update values, take readings, turn things ON/OFF, etc.. Pretty much just get in and get out.
    Your example is like the one Henrik suggested but within the ISR.
    But got another wild idea if your tight loop can sacrifice just a little time to test the ISR flag bit:
    INT VAR BIT
    INT = 0
    loop1:
        code
        IF INT THEN GOTO loop2   ' Jump to loop2 after loop1 finished if interrupt triggered
    GOTO loop1
    loop2:
        more code
        IF !INT THEN GOTO loop1  ' Jump to loop1 after loop2 finished if interrupt triggered
    GOTO loop2
    ; --------------  ISR toggles a flag bit ----------
    Button_ISR:
        INT = !INT
    @ INT_RETURN
    This way, I'm thinking, any one of the loops can complete it's mission before jumping to the other routine should an interrupt happen. Or just continue in it's loop until the button is pushed.
    Louie
    LOL, I already did in the same way, just it became necessary to rise clock frequency to 32mhz. But I don't use any interrupts, and it works just fine.
    Nov 2007
    West Covina, CA
    Default Did it already
    Hehe, that is funny.
    Glad you got it going.
    Louie
  1. TOGGLE will not go LOW
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 10th August 2014, 17:53
  2. toggle switches and buttons-- need little help
    By electromark in forum General
    Last Post: - 25th October 2012, 23:35
  3. Toggle command
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 16th December 2011, 03:07
  4. toggle or count?
    Last Post: - 26th May 2008, 09:54
  5. BRANCH/BRANCHL for GOSUB
    By selbstdual in forum PBP Wish List
    Last Post: - 20th February 2007, 15:29
