Toggle program branch ussing interrupot by button?
Results 1 to 14 of 14
    Default Re: Toggle program branch ussing interrupot by button?
    with PBP "on interrupt" it looks this figure is covered in the manual @ $ 5.66 ( RESUME xxx ) : you can choose the "return" adress xxx as you want ... so LOOP2 always completes.
    - also note if you do not clear the interrupt flag ( With a DEFINE ) you automatically re-enter the ISR when completed !
    - For DT interrupts ... I didn't check if the resume address can be freely chosen ...
    - last idea is simply to overwrite the interrupt return address on the stack ... ( with asm "push" and "pop" macros see midrange manual, interrupts chapter ), depending on the button state.
    I don't want to include the button status check routine in the loops, since whole program works with microsecond delays and high accuracy. This is why I wanted to use interrupt. LOOP1 and LOOP2 are totally independent tasks, they don't use same variables, timings or whatsoever.
    Nov 2007
    West Covina, CA
    That's a good question...
    I wonder if something like this would work?
    x VAR BIT
    ;----------------------- Setup Interrupts --------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Darrel Taylor's Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ; Include if using PBP interrupts
    INT_LIST  macro ; IntSource,          Label,  Type, ResetFlag?
        INT_Handler    INT0_INT,     Button_ISR,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    ;----------------------[Initialise Interrupts]-----------------------
    @   INT_ENABLE  INT0_INT         ; Enable Button interrupt input
    x = 0       ' Clear button status flag bit
    PAUSE 100
    GOTO loop1  ' Start at loop1 routine
    ' ---------------- Independent program routines -------------------------
    loop1_start:
    @ INT_RETURN    ; Reset the ISR
    loop1:
        ' Perform one type of "time critical" function
    GOTO loop1
    loop2_start:
    loop2:
        ' Perform a different type of "time critical" function
    GOTO loop2
    ;--------------------[Program routine selector ISR]----------------------
    ; make sure button signal debounced
    Button_ISR:
        x = !x      ' Toggle x status flag bit
        IF !x THEN
            GOTO loop1_start    ' Go here when x=0
            GOTO loop2-start    ' Go here when x=1
    @ INT_RETURN
    Like Henrick said, the routines could be cut short anytime the button is pushed though.
    Louie
    Thanks. As I can see, the code is for PIC18xxx family. Will it work on 12xx or 16xx ?
    Nov 2007
    West Covina, CA
    Not for PIC12's or 16's.
    You'll have to download DT's Interrupts for them here and replace entry with:
    INCLUDE "DT_INTS-14.bas"    ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"    ; Include if using PBP interrupts
    I was kinda hoping someone would point out my errors in my suggestion, if any, before you went too far into a possible dead end.
    If you haven't tried DT's INTS, you're missing out on some awesome timing control when it comes to sequence of events. It took me a little while to understand but finally got some handle on it when I monitored two interrupts taking turns to run their routines, especially when one occurs while the other ISR is taking care of business.
    Louie
    Ok Louie, I'll take a stab at that if you wish... :-)
    If the program is looping around in Loop2 (x=1) when the interrupt occurs the ISR will toggle x to 0 and then GOTO Loop1_Start.
    At Loop1_Start there's an @INT_RETURN which will send it back into Loop2 since that's where it was when the interrupt occured.
    Nov 2007
    West Covina, CA
    Thanks Henrik, I stand corrected.
    CuriousOne, I tried to do something like this in the past and thought I came up with a better idea all of a sudden, but to avail.
    Louie
    I found a sample code here:
    http://darreltaylor.com/DT_INTS-14/hello.html
    The code is OK for me, since I also need a selected loop indication via led. What if I mod it a like this:
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    IF LED1=1 then goto LOOP1 ELSE GOTO LOOP2
    LOOP1:
    LOOP2:
    @ INT_RETURN
  1. TOGGLE will not go LOW
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 10th August 2014, 17:53
  2. toggle switches and buttons-- need little help
    By electromark in forum General
    Last Post: - 25th October 2012, 23:35
  3. Toggle command
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 16th December 2011, 03:07
  4. toggle or count?
    Last Post: - 26th May 2008, 09:54
  5. BRANCH/BRANCHL for GOSUB
    By selbstdual in forum PBP Wish List
    Last Post: - 20th February 2007, 15:29
